  • Replies 53
Well, yeah.....the clutch in the converter.
Hi. I'm having a problem with my stock rb25det auto box slipping. I am 99.9% sure the culprit it worn out burned out clutch plates. Are you saying If I simply swap out the torque converter and keep my box I will have a fresh set of clutch plates?
This is good news if that is the case.
There are 5 or 6 clutch plates for each gear, and steel plates between them. (Like a motorbike clutch pack.) The clutch plates only have 0.5mm of material on them so when they slip it doesn't take much to wear them to metal requiring a rebuild.
They have in excess of 200psi oil pressure pushing the pack together when locked so there is massive heat generated if slipping occurs, more than enough to warp the metal plates between the clutches. If you get the box rebuilt they will usually toss the lot and laser cut some thinner metal plates, to allow extra clutches to be installed in each gear's clutch pack. That way it can hold more power.
That still doesnt answer if the cltuch plates are in the torque convert or the inside of the transmission.
GTSboy answered that. There is a single plate lockup clutch in the torque converter, it's job is to obviously lock up the torque converter, to make it direct drive, like a manual clutch.
There are also many clutches in the gearbox for the gears, and a band (like a drum brake) to slow the car when you back off. If yours is revving right out on slip it will be the gear clutch which has worn. If it only revs out onto the stall converter speed, it will be the lockup clutch that is faulty.
My bad. Well while we're on the topic. Its Difficult to address what you raised unless you know exactly what I mean. The car is not revving out at all. In fact it begins to stall and shifts like a brand new box. The problem is there isn't a direct engagement between the Engine and wheels like there should be under WOT, or even 1/4 throttle sometimes. I am not talking about the first few seconds or pulling out of the driveway.
After a certain point when pressing the accelerator the car stops continuing to accelerate and starts to shudder back and forth a bit. By this I mean the increasing rate of acceleration as engine RPM rises, halts. The car obviously still picks up speed in this state, but it would look like the powerband has flattened out on a dyno at 3000rpm but its not due to lack of power from the engine doing it. I hope you get what I mean by all this.
In addition, I think the ECU backs of timing or lessens power output depending on the state of the transmission and even when the clutch it slipping. I can also feel it cutting power in between shifts. This is normal, but it seems to confuse people to think the transmission works and sfhits normally, whereas I can easily detect when there isn't direct engagement. Its like if you held the clutch at 3/4 lock in a manual car and as soon as you felt slip backed of the throttle and kept it there. Its not right.
Edited by sonicz
Sounds like what a torque converter should be doing. It should unlock as you accelerate and lock again once you are cruising, allowing the engine revs to rise onto stall when you boot it. Perhaps you have a high stall converter fitted already which may make it seem worse than usual?
Yes, the stock ecu mapping backs out timing between shifts.
I'm not that familiar with the inner workings of an AT. What I do know is I can feel G forces in a car, and what is happening increasing acceleration it halted somewhere down line of the engine. I dont think its normal for at transmission to be the limiting factor on acceleration.
The following is a good anlogy of what i mean by direct enagement, Its kind of like wheel spin. When your wheels are not loosing traction, you have direct engagement with the road, but if you exceed a certain point and your wheels begin to slip, no matter how much HP your engine puts out, your acceleration will be limited. Solution is to get more grip on the tyres, not giving the engine more HP. The same thing is happening here.
Ive owned a few 300HP+ AT cars. I know in my mazda (200,000ks+ and previous owner never changed At fluid) I had the same problem. Mechanics said box works fine. they just drive it, checks if it shifts smoothly and that is all. Doh!
But I knew it wasnt. I was lucky enough to find a brand new box for $2000 during a mazda warehouse clearance and had it fitted. The car felt like it double the power. No more slip.
Does anyone know if the RE4RO1A auto that is behind the rb25det in the r33 (also behind 300zx non turbo)
Is this auto in any other skyline.
I've been looking on eBay at the autos that are in r32's & r31 series 3 ,the pictures that people have look like the same autos
Can any one confirm this is true
The series 1 and series 2 R31 had the 4n71b. .series 3 31 +32 +33 are all re4ro1a
Series 1 R34 has the re4ro1B
Series 2 R34 has a different trans again afaik
The y31 cedric etc has a stronger re4ro3b
Has anyone connected a b&m shifter to one of these autos
I'm planing to make it 4 speed on the shifter instead of 3
4th gear is run of a switch when using a b+m shifter. If you are going to use a b+m shifter buy the correct brackets to make it work correctly
From what I have found there was only one company doing a trans brake manual valve body but they went broke last year. All 4 speed jatco boxes have an electronic solenoid to engage 4th not activated through the selector
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
