This was my first GTR35 set which I completed for a local car. I ended up attempting the True Quad setup and I was pretty happy with the way they turned out. I learnt quite a lot from this first set. Ill know what to do and what not to do for future sets.
Enjoy the pix....
HL specs:
* JDM GTR35 headlights
* Quad Mini H1 5.0's
* White painted cutoff shields
* TRS side emitting LED strips for the new "Parker" setup
* Mini Gatling Gun shroud (Low beam housing) + regular Gatling Gun shroud (High beam housing)
* Full Satin Black finish using: VHT Prime coat SP305 "Satin Black"
CLear lense pulled off
OEM low beam projector vs Mini H1 5.0.
Both lense holders are lined up. Very similar sized projectors
2.5" Mini H1 lense vs Slightly smaller OEM lense (forgot to get a measurement)
Mini H1 fits like a glove in the OEM low beam reflector bowl
Even the OEM headlight bezel fits around the Mini H1 without any modification. Looks just like factory :) Happy days!!!
Anyone that wants to do a projector upgrade on a GTR35 HL will have the least hassle free experience with a Mini H1.
* minor dremelling of the housing underneath the projector
* JB Weld / Stik Mini H1 to the OEM reflector bowl
* Fit OEM bezel (without modifiaction)
Done deal!!
Bottom section of the OEM projector still needs dremelling
This is the dremelling I was talking about to fit the Mini H1. This helped with rotational alignment.
Close up
Both projectors fixed in place using JB Stik. You can see the M4 nuts & bolts thats helping to extend the Mini H1 in the High beam housing
Side emitting LEDs installed and showing off the new "Parkers"
Heres a mock up of how I want the Gatling Gun shrouds to look
The first initial cut on the Mini GG. I was still afraid to hack into the OEM low beam bezel incase I couldnt pull off the look. Once you cut into it theres no turning back...
Sliding the Mini GG inplace... Still requires a lot more cutting..
Finally bit the bullet!!! Had no choice as the Mini GG shroud was not going to "slip" in any further without cutting the OEM bezel
More cutting leading to a better fit
Getting closer and closer
The final look of the OEM low beam bezel. No more cutting
Mini GG trimmed to a final depth of 45mm for the best fit
Test fit
The first initial cut of the OEM high beam bezel
Test fit of both Gatling Gun shrouds with electrical tape holding them in place
Gardening wire hold the Gatling Gun shroud to the OEM headlight bezel
JB Stik applied as the primary adhesion
JB Stik finally cured and hold the shrouds in place
Dressed in Black
Turn signal housing masked up before the Satin black finish
Assembly line
All that left to do is seal the HL up
Testing the LED strips
H1 bulb now protrudes from the back of the high beam housing. The dust cap no longer fits.
Giving my plastic welder the vital info he needs: ">PP
That looks amazing :woot: Seems like very fiddly work with a lot of thought put into what to cut/what not to, but in the end looks like a concept R35 headlight, just 100x tougher. Awesome!
Edited by colourclassic
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
