This was my first GTR35 set which I completed for a local car. I ended up attempting the True Quad setup and I was pretty happy with the way they turned out. I learnt quite a lot from this first set. Ill know what to do and what not to do for future sets.
Enjoy the pix....
HL specs:
* JDM GTR35 headlights
* Quad Mini H1 5.0's
* White painted cutoff shields
* TRS side emitting LED strips for the new "Parker" setup
* Mini Gatling Gun shroud (Low beam housing) + regular Gatling Gun shroud (High beam housing)
* Full Satin Black finish using: VHT Prime coat SP305 "Satin Black"
CLear lense pulled off
OEM low beam projector vs Mini H1 5.0.
Both lense holders are lined up. Very similar sized projectors
2.5" Mini H1 lense vs Slightly smaller OEM lense (forgot to get a measurement)
Mini H1 fits like a glove in the OEM low beam reflector bowl
Even the OEM headlight bezel fits around the Mini H1 without any modification. Looks just like factory :) Happy days!!!
Anyone that wants to do a projector upgrade on a GTR35 HL will have the least hassle free experience with a Mini H1.
* minor dremelling of the housing underneath the projector
* JB Weld / Stik Mini H1 to the OEM reflector bowl
* Fit OEM bezel (without modifiaction)
Done deal!!
Bottom section of the OEM projector still needs dremelling
This is the dremelling I was talking about to fit the Mini H1. This helped with rotational alignment.
Close up
Both projectors fixed in place using JB Stik. You can see the M4 nuts & bolts thats helping to extend the Mini H1 in the High beam housing
Side emitting LEDs installed and showing off the new "Parkers"
Heres a mock up of how I want the Gatling Gun shrouds to look
The first initial cut on the Mini GG. I was still afraid to hack into the OEM low beam bezel incase I couldnt pull off the look. Once you cut into it theres no turning back...
Sliding the Mini GG inplace... Still requires a lot more cutting..
Finally bit the bullet!!! Had no choice as the Mini GG shroud was not going to "slip" in any further without cutting the OEM bezel
More cutting leading to a better fit
Getting closer and closer
The final look of the OEM low beam bezel. No more cutting
Mini GG trimmed to a final depth of 45mm for the best fit
Test fit
The first initial cut of the OEM high beam bezel
Test fit of both Gatling Gun shrouds with electrical tape holding them in place
Gardening wire hold the Gatling Gun shroud to the OEM headlight bezel
JB Stik applied as the primary adhesion
JB Stik finally cured and hold the shrouds in place
Dressed in Black
Turn signal housing masked up before the Satin black finish
Assembly line
All that left to do is seal the HL up
Testing the LED strips
H1 bulb now protrudes from the back of the high beam housing. The dust cap no longer fits.
Giving my plastic welder the vital info he needs: ">PP
That looks amazing :woot: Seems like very fiddly work with a lot of thought put into what to cut/what not to, but in the end looks like a concept R35 headlight, just 100x tougher. Awesome!
Edited by colourclassic
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
