I would walk into an exhaust shop or performance workshop carrying that turbo and exhaust kit and ask to buy sufficient suitable fasteners to hold it all together. The dump is usually held on to the turbo outlet with a mixture of bolts and a couple of studs (due to lack of access to get bolts through). The dump onto the down/front pipe will want decent fasteners that can take the heat. (Same with the turbo-dump fasteners for that matter, plus you want to have decent dome washers or locking fasteners or lock tabs or something to stop them coming loose and falling off).
That "blow off valve" is not a BOV, it is a wastegate, which you won't need if you swap back to standard turbo.
Your question marked blue hose elbow needs to be replaced with the original cast alloy crossover pipe, if that is what your new cooler piping kit is intended to hook up with. The cross over pipe also has the point where you put the BOV, plus it has some tapping points used for connecting parts of the emissions gear. If you put a factory BOV onto the factory cross over, you'll also need to put in the pipework to take the BOV outlet back to the turbo inlet.
I tend to agree with the other guys here. You would be better off getting the stuff you have on the car working than trying to go back to stock. Too many niggly things you need to do it right.
The wheels issue is best solved by pissing them off and fitting either stockies or aftermarket ones that actually fit. There is very little reason to use spacers to make the wrong wheels fit beyond appearance/fashion, and cars should not be made to look in a particular way at the expense of functionality. To do so is to not masculine.
Edited by GTSBoy
Also keep in mind that spacers for your wheels are illegal and defectable
Not sure why others on here are even suggesting you use them when other options are out there
edit. point has been made and discussed.
^^ this! get someone (any furkn one!) who can sort this for you
You are trying to use a combo of stock and aftermarket parts(some good and some not) and trying to make it work for you
The way you are approaching this is going to end in tears and an empty wallet
You really don't listen to anything I have tried to tell you do you...GL with it champ....you'll need it :thumbsup:
Sorry, couldn't get a good look at the object as it was under my manifolds and i'm new to turbos/ wastegates, it looked totally different to the stock one.
thank you for the information, it was very helpful. i might take everything i have into a shop and see what they can do.
Heres a video on how it runs for anyone that's intrested:
[uploading]
Edited by iTwix
Agreed, its like he is missing all the advice thrown his way
i'm listening to a lot of information. I came into this thread without knowing any of the fuctions of the parts i had, now i know exactly what they do and exactly what i need to achive the build.
i apreciate all comments negative or positive
and we appreciate your thread ....you know, for the larfs it has brought us
i hope you get it going one way or another coz it actually looks like a nice 33 ... :thumbsup:
dave your a kent. but i love ya.
mate. seriouslsy. you are not listening.
put down your tolls, wallet, shitty parts. ask for a pm from someone close to you. call them. let them look. write down what they tell you needs to happen. do it.
pull farkin skids farken.
i've had 2 people from jap car clubs to come have a look at it, and i've taken it to various performance shops recommended by others.
what you need is some under bonnet pics of a stock standard engine bay then go search for the parts, quite simple really
im returning mine to stock and will take some pics for you..
some more pieces to your puzzle
Edited by AngryRB
UPDATE: just blew the old turbo, defiantly rejoicing over my decision to buy stock turbo. Glad i didn't throw on fuel rails and try to tune that setup, like some suggested haha.
Question: can i limp a blown turbo around if i stay off boost for a week?(no smoke yet)
Edited by iTwix
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
