Hey All!
Hopefully this is the right place to ask for some advice...
So recently I purchased some weather shields off SAU and they got couriered to me. They arrived late Friday night, approximately 7:30 PM.
As you do, you quickly have a look at see if it's your item and sign for the parcel.
It was only till Saturday when I unpackaged it, the bloody courier service snapped one of the weather shields. They are the OEM Nissan ones, so they're quite flexible however this moron must have dropped something heavy on it and damaged it.
So as you do, you contact the courier company's customer service. This was their response:
(customer rep's name, contact details removed)
Hello Johnny,
Thanks for your email.
Unfortunately, once an article has been signed for, it is deemed to have been delivered in good order and condition. Accordingly, we would not be able to offer insurance in this instance.
Please refer to our terms and conditions of carriage which are available via our website at www.fastway.com.au.
Should you have any questions or require any further assistance, please do not hesitate to contact any member of my team.
I really think that's a croc of shit. Should I take it up with the ACCC?
Id suggest ringing them and talking to them. A polite conversation and a bit of haggling normally sorts out most dramas with Telcos, couriers, shops, insurance companys etc for me. emails all good but most of the time they'll just send a generic reply like the one you got.
Im my experience I have never received compensation for damaged goods. I have even had to replace items I have sent to someone else because they were damaged in transit.
ALWAYS CHECK the item you are receiving BEFORE signing, it pisses the couriers off badly but screw them, it's your item not theirs.
Unfortunately you there is nothing you can do, other then never use them again. Once you have signed for the delivery in good order you take full responsibility. Sucks but look at it from their perspective, how many customers would try to claim damage/loss because of their own stupidity? They'd go out of business very quickly. If in doubt make the courier wait while you check the goods. If the courier doesn't want wait then make them (not you) make a note on the POD. The courier will always try to rush you, don't make their schedule your problem.
I work in IT distribution and part of my job is dealing with missing/damaged goods. To be honest, I start from the position of the customer doesn't know what they are taking about and I'm usually right.
Always have a signature delivery, don't accept "Left as instructed" and take the time to inspect goods, making a note of any little mark.
sorry to say, any courier company is expert at denying responsibility for broken goods....they do it all day every day. I can't see you getting far arguing with them, why would they change their position :(
Seller arranged it with fastway couriers... I doubt the seller would sell broken goods he's a SAU NSW member.
Ok the seller has contract with courier for bailment of goods. Get seller to contact courier. If this fails, contact department of fair trading, they'll help you out.
Go straight to department of fair trading.
I'm dealing with this at the moment via transdirect. An item I sent to a customer was damaged in transit, and after dicking me around for two months they have rejected my insurance claim based on insufficient packaging (the f/glass wing was was packaged with three inches of bubble wrap all the way around, and cardboard on the outside, and marked fragile...) according to manufacturers specifications (there are no manufacturers specifications, I know this because I'm the only one importing these goods in AUS). Rang to discuss and the receptionist says can't discuss insurance via phone, all managers are in a meeting and unable to speak with me, no management don't have a direct line and no I can't tell you when they'll be available.
As has been posted these companies are pricks and experts at denying liability.
Fair trading process can be a long one (up to 30 days for Fair Trading to respond), lodge your claim and cut your losses...
I'll speak to the seller and see how we go.... might just be a total waste of time for me, as these are just OEM Nissan weather shields.
I'm waiting for the seller to send me the original receipt
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
