I got no mic and some little 14 year old was bagging me out. Nearly smashed my controller because I couldn't have a go at him.
ahhahahaha well fark me seems like my ps3's wirelss has decided to conk out, or something else wrong with it, i cannot get it to connect to the net and thus i haven't even DLed the online update yet....fark me.
no biggie though, i don't mind waiting a while until the online gets ironed out a bit...i just hope my wireless somehow comes back or else im gonna be pissed...and buy a ps4
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
