Strange because when I was playing last night it popped up saying "89Cal joined SAU"
Yeah that is a bit odd.... I joined a few days after the crew was created.....
Blew some money on my car today, its to hard to save for properties :P
Also, my PSN name is CAL096 if it has caused any confusion. Its not a 17 year old imposter
Edited by 89CAL
you meant the GTA races? they are retarded lol. spent both races trying to figure out how to use the pickup weapons. trying to finish a race in a supercar with no rear tyres... kill me now
I think LordUmadbro and NISMO_R31 (or whatever) are due for promotion. good players, doing the crew proud
thanks dude - will check em out :)
anyone know how to use the weapons you pick up in GTA race? google only brings up the f**king usual results "how to make your dick hard on gta 5 and level up quickly" "10 reasons why this website is shit (gta 5)" etc.
f**k console people. seriously.
Press down L3 :)
Yeah, it seems console peasants have problems in making actually helpful topics ;)
Hey guys can you please post your ranks in here.
A few people aren't sharing their ranks via the social club so it's hard to tell if you are an active member or not.
I'm playing around with the hierarchy because a fair few people have joined but don't play online very often
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
