haha hte missions were fun, except when i was driving the banker from the airport and just went the wrong way and looped the airport...derp.
definatly need more team missions,im on tonight so ill see who is on,
i always click the join crew option and it just kicks me back to the map....shrugs?
Steal cargo helicopter.
Hook up random player in his car.
Go really high.
Drop him. Listen to them rage.
Laugh.
Or take them out to sea and drop them. Fkn lmfao when they lose it
  • Like 3
/\ hahah
I trolled a guy hard onTuesday night. I was chasing him for 15 mins (me in chopper him in car) after he shot at me for no reason. He finally goes to the Hospital and takes the bigger chopper (twin rotor) with grappling hook. I end up destroying one of the rotors and it crashes. I notice he was driving to the hospital again and land on the roof before and shot him. He re spawns and in the mean time I put stick bombs on the two choppers on the roof and fly off to an adjacent building. As he proceeds to take off and head directly at me I detonate the sticky bomb..
"xxxx has left" <---- hahah rage quite hard!
GHOST sorry for running you over while waiting for you to get in the car........and then laughing in your face, it was just too funny! otherwise we had some good mission fun! I promise i won't do it to you again......this week :ph34r:
Frosty I think i'll be on for a little while at least, usually elchino and GHOST is as well.
Go really high.
Laugh.
That is the best idea I've heard in a long time :P
Need to find cargo helicopter now.....
think it does that when no one is on from the crew. i went on and tried it aswell. ill give it a razz tonight
yeah it wouldnt let me get in your car, kept kicking me out, i was actually trying to get you to run me over, which is why i jumped on your roof, i have a bounty on me, you should have claimed it lol.
i really need a headset so i can talk
last night freaked me out, some random dude sprinted right up to me, face to face, just before i punched him he blew his own brains out....wasnt sure how to feel. very random indeed
Have to get a few people and do a game of survival. Had a go yesterday and it was pretty fun. Hard to master in Sandy shores survival but the one at the boneyard has a few vantage points and would be easier
how do you throw sticky bombs at cars, from your car and get them to detonate? i cant figure it.
in car the are basically dropped on the road as your drive.
Holding L2 to aim like a gun will lock on, R2 to throw. Left D-Pad to detonate at anytime
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
