sorry to say but I'm having to pull out to, still can not get the computer to start the car and the tuner left today for Sema till the 18th of nov
was so looking forward to this, might still come down with Paulie for some good old fashion drinking though :thumbsup:
Hey Ryan, I sent an email on the 31st October, confirming I was out. Embarrassingly I had double booked that weekend, as my best mate's has his wedding on the same day, and invites were sent 3 months ago, to which I'd RSVP'd my attendance and then stupid me, getting all excited and shit cause my MelbS15 brethren will be there in force agreed to enter, and yeah, stupid :( Sorry for stuff around.
Ok. So if you are pulling out please msg me with all your details such as first and LAST name ta ;)
Minal Doolbah M3
Elliot Kerby E30
Matthew Robins E30
Chris Lack R32GTST
The above guys are in. There are currently no reserves.
Please make sure that payment has been made.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
