So is there still a spot available? Seems so from the OP. Have a mate who has back for the weekend and would like to come down with his S14 if there happened to still be a spot free?
If there is let me know and I'll get him to submit form and make payment ASAP. Thanks.
There should be a spot free, a few always pull out in the days leading up if/when the car isn't ready on time...
Submit the form and pay asap and he'll be squeezed into the reserves list, if not directly into the entry list. Refunds are available if you don't get into the list, obviously.
AT THE MOMENT THERE IS A TOTAL OF 3 VOLUNTEERS :dry:
PRETTY SIMPLE PEOPLE:
NO VOLUNTEERS = NO DECA
PEOPLE THAT ARE BRINGING FRIENDS PLEASE MAKE SURE THEY VOLUNTEER
THERE WILL BE TIME FOR THEM TO GET A RUN WITH YOU, ALSO THEY GET CLOSE TO THE ACTION
Jake is spot on. We very much need volunteers for this event. If we cannot get enough then we will have to cull events from the day.
We need a minimum of 10 people for the morning events and 5 for the afternoon battles.
Not a problem. Tell bec when you Sign in.
For anyone coming to winton, we are aiming to be there around 930-1000am. There is no briefing. It will be run in 3 25 min groups.
ALRIGHTY PEOPLE, DECA TOMORROW
PLLLEEEAASSSEEEE BE ON TIME 7.30
AND
PLLLEEEAASSSEEEE HAVE YOUR CAR READY, eg fire extinguishers, no crap in your car etc etc.
See ya's all tomorrow morning nice and early :thumbsup:
ok so after 8 hours of driving, I finally got home had a long hot shower and a nana nap and feel almost normal again
I have to say a big thank you to everyone, the organizers for such a great day and everyone that made me feel very welcome while I was there and the courses are just insane, can not wait to come back
The high light for me though was the saturday night dinner, I haven't laughed so hard in a long time
bring on some pics and vids, I imagine there will be some really good ones
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
