First checkout the link below for proof I can be trusted to post as I'm an ebay POWER SELLER:
http://feedback.ebay.com.au/ws/eBayISAPI.dll?ViewFeedback2&userid=iphone.addiction&ftab=FeedbackAsSeller
I'm willing to negotiate if your taking multiple items:
Apexi PFC + Manual (for R32 & R33 GTR) $700
Blitz i-Color SBC Dual Solenoid $600 (Only USED for a couple of months, before uninstalling for storage almost 3 years ago)
AEM 8 Channel CDI Module $400
1996 R33 GTR Turbos done less than 100,000kms $400
JVC stereo RRP was $2700+ $350
Datalogit USED less than 10 times $320
pexi RSM Limited Edition + G-Sensor $250
TR 485cc Injectors x 6 $250
pexi FC Commander FCC3 new Style Multi-version 415-X001 $240
Innovate XD-16 (Gauge Kit) USED less than 10 times RRP$265+ (or take it with the LC-1 for $300 RRP$360+) $185
GTR ECU $180
Apexi 3 Bar Pressure Sensor 499-X001 NEW $160
Apexi 3 Bar Pressure Sensor 499-X001 USED less than 10 times $130
R32 GTR Main Gauge Set $150
Innovate LC1 (Wideband Kit) USED less than 10 times RRP$200+ (or take it with the XD-16 for $300 RRP$360+) $140
AEM PLX EGT (Exhuast Gas Temp Sensor Kit + Adapter for O2 bung) USED less than 10 times RRP$155+ $115
Nismo Front Strut Brace $120
R32 GTR Rear Spoiler $120
R32 GTR 3 Gauge set $120
Apexi Boost Solenoid 499-X003 for AVC-R or PFC $100
GTR AFM done less than 100,000kms $110 (*EACH)
R32 N1 Bonnet Lip (Preped & Ready for Paint) $100
GTR Coil Packs x 6 done less than 100,000kms $100
R32 GTR Climate Control $90
Sard Fuel Pressure Reg $90
Apexi Power Intake Dual Funnel Universal 75mm Air Cleaner NEW $80 (Each)
Stainless Steel Decat pipe 3" (with O2 bung & plug) + 2 NEW Gaskets $80
Hicas Lock Bar NEW $80
Alternator $80
Blitz DTT Turbo Timer (displays boost can be set on Auto using boost/vac or time) $55
Blitz FATT Turbo Timer $45
22x Narrow / Light-Weight Wheel Nuts + Tool for Thread 1.25 x 12 $55
Apexi Boost Pressure Sensor 499-X002 for AVC-R $50
HKS Turbo Timer with NT-1 Harness (vehicles suited are listed after the harnesses below $50
R32 GTR Ash Tray $50
R32 GTR N1 bonnet lip Needs Attention $40
R32 GTR Fuel Rail painted RED $40
R32 GTR Full Set of Blue LED's for Gauges $30
Fuel Pressure Gauge $25
Apexi Boost Pressure Sensor Harness NEW or USED $15
Turbo Timer Harness NT-1 for BNR/HCR/HNR32 S/PS/RS/RPS13, A31, RNN14, VNW30(95/8-On), C23(95/8-On) $20
Jack NEW $20
Rim Spacers 5mm $20
Cheap & Nasty Boost Gauge NEW $15
R32 GTR Headlight Relay $10
YOU MUST CONTACT ME BY PM OR EMAIL
Pick up from Wyndham Vale VIC (sometimes Dover Heights NSW)
Or
Postage with Tracking $20 or with Signature $23
Contact Brett at [email protected]
KD-AV7008 wiring diagram.pdf
Edited by Sydneyactionman
  • Like 2
pic/model of jvc stereo?
I had already attached a PDF that gives details of the model! Here are some photos!
As per the photo the original price from JB hifi was $2599 but it sold for up to $3K in other places!
NEW PRICES & WHATS LEFT:
Apexi PFC (for R32 & R33 GTR) $700
Blitz i-Color SBC Dual Solenoid $580 (Only USED for a couple of months, before uninstalling.)
1996 R33 GTR Turbos done less than 100,000kms $330.
JVC stereo $350 (RRP was $2700+)
Datalogit USED less than 10 times $300
Apexi RSM Limited Edition + G-Sensor $250
GTR 485cc Injectors x 6 $210
Apexi FC Commander FCC3 new Style Multi-version 415-X001 $230
Innovate XD-16 (Gauge Kit) USED less than 10 times RRP$265+ (or take it with the LC-1 for $300 RRP$360+) $180
GTR ECU $160
Apexi 3 Bar Pressure Sensor 499-X001 NEW $150
Innovate LC1 (Wide-band Kit) USED less than 10 times RRP$200+ (or take it with the XD-16 for $300 RRP$360+) $130
AEM PLX EGT (Exhaust Gas Temp Sensor Kit + Adapter for O2 bung) USED less than 10 times RRP$155+ $110
R32 Nismo Front Strut Brace $120
R32 GTR Rear Spoiler $110
R32 GTR 3 Gauge set $100
GTR AFM done less than 100,000kms $100 (EACH)
R32 N1 Bonnet Lip (Prepped & Ready for Paint) $90
GTR Coil Packs x 6 done less than 100,000kms $90
Sard Fuel Pressure Reg (Cost me $200, it's NOT a $50 knock off) $80
Apexi Power Intake Dual Funnel Universal 75mm Air Cleaner NEW $70 (Each)
Alternator $80
22x Narrow / Light-Weight Wheel Nuts + Tool for Thread 1.25 x 12 $50
Jack NEW $20
Rim Spacers 5mm $20
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
