You sneaky rat ! YOU UNEDIT WHAT YOU SAID ! NAOW!
Thursday - thanks guys. She is going through this time !
I had a temporary empathetic moment so withdrew original post. It will not happen again :no:
It had something to do with the length of this thread and related to your 1kFred and the speed at which your vehicle travels ....... :rolleyes:
  • Like 1
wait so you didnt end up putting i the rest of the bolts for the stock airbox?. i was late dude i only put in enough to secure it. Donno I maybe wrong but arent you're only allowed one intake mod either pod or intercooler? lemme know if you're using the stockies too. might come pick them up for spares for Wakey.But if you are dont fret
I didn't know I was bolting it in haha I had plans for putting the stockies on today at robs - I seriously lack tools to which I need to purchase some form of car kit like you have. Also, as I've said before - I was not marked down for the intercooler / Pod filter. I'd rather get done for a pod filter and nothing else becuase of the easy change over. Atm, my car is struggling to have a defect (Yes I know, it's easy to find a defect - but at a cheap cost?). Plan is to force them to pick the airbox so all I have to do for the re-test is change an airbox, if it does not get pinged well, lucky me / they'll probably find something else. Besides, the holes do not line up so bolting it in will be missing bolts regardless.
In short - my car will not be passed first go - but I rather them find an easy fix to ping me on then saying "oh, it appears your car has chassis damage - go get it fixed" nekminit $3k later.
Edited by RosieR34
This is incorrect.
Not sure who made this up, could even be a NSW rule but it does not apply in ACT and shouldn't in Australia either for Skylines. Skylines (R32-R34) had factory fitted front mount intercoolers (GTR model) so it is not a modification, just a replacement part.
This is incorrect.
1 cold air intake is a Vic law. However the "replacement" is defined as legal here yes?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
