Read this thread - ultimate RB "pull hard" setup, make numbers in the range of GT35R peak power but spooling similar to the smaller GT30 range turbos:
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
+1 for lithiums post. HTA turbos are weapons and will give you the best of both worlds. Will give you 400rwkw and the same response as a gt3076.
You'd be mad not to have a look basically
I disagree with both these clowns :ph34r:
LOL kidden, HTA or GTFO!
Was just trying to be helpful, was Garrett based and a lot of people don't know there is a bigger world than Garrett who have been all but left in the dust. But point noted, I have meant to have given up on trying to be "helpful" on these forums - just got a brief burst of enthusiasm for this place after finally actually meeting some SAUers... as you were :action-smiley-069:
Asks about Garrett offerings, gets advice on every other manufacturer but... :P
Well technically Garrett make the turbos with the HTA wheel :P So sort of got it...
Hhahah
I get the same thing.
Left in the dust is a little excessive, I love my GTX and the results are excellent imo. Keep your HTA fanboi speeches for the impressionable boys in the FP thread. Considering you all talk about them continuously I would find it hard to believe someone hasn't heard of FP, Precision or BW for that matter.
I think Garrett is still king of reliability in most peoples minds... for good reason. If that means they are a little slower in their design rollouts and test their turbo's for longer, I am all for it. I have a Precision 6766 on the bench at the moment, not sure I like how thin the compressor blades are. Hopefully they haven't gone too light weight just to beat the competition...
No need to sook about being 'helpful on these forums', everyone else is here for the same reason. If you don't like people having opinions that differ to yours, better stay off the interwebz.
Hi all
I read some comments here and it looks like people prefer GT30 for around 290-320rwkw power. GT30 will come on boost harder in the mid range. It looks like a more efficient option on paper.
One thing I don't understand is why would someone want harder pull in the mid range when it will create more problems with traction unless are on 3rd gear. I have rb25 with GT35 312rwkw and I have problems with traction on 2nd with 265s and shimmed diff. I've driven similar car but with a smaller turbo and it had even less traction.
Correct me if I'm wrong, since I'm new to this. If I floor it at ~3000rpm it will pull hard almost instantly and easily break the traction on a smaller GT30 turbo compared to GT35 which pulls from ~4500+ but has smoother transition from no boost to full boost.
I have read many threads about this but not many people are looking at it from this angle
Cheers
Hi all
Cheers
You'll find your traction control switch at the end of your right leg; when traction starts to break, lift right leg slightly.
Also on most good ECU's you can do boost by gear and just have less boost in 1st and 2nd.
No reason you can't just lift off slightly though...
Maybe of interest, I found this helped with controlling boost on my car:
http://www.gktech.com/index.php/v2-s14a-s15-eccentric-throttle-wheel.html
It will work fine on an RB25DET. The standard wheel opened the throttle quite a lot with little pedal movement, where as the GKTECH one is the opposite, ie a smooth logarithmic opening of the throttle, where 50% pedal may only be 30% throttle opening. (not sure about exact numbers)
Its good for peaky responsive turbos.
the best action ive had was with a GTX3076, 4000rpm's = Hammer time, 1st and 2nd at WOT =Black lines layed for 50meters which is f#$k yeah feeling.. 3rd= hold on
If you can do this then you know you got a wild ride, the rest is up to you and the tyres, suspension and right foot control, but personally this has set the bar for me... and now disappointed with anything less :(
Go with the Gt35. They are the bomb diggity.
They also have plastic cage bearings afaik, where as the GTX has steel cage. Hence the reason the old diesel designed GT35's have a higher failure rate. It's one of the Garrett turbos I wouldn't recommend.
Go with the GTX3076 imo for a similar power figure and quicker spool.
not wrong here. The GTX3076 is awsome fun. i love it!
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
