I'm assuming this is for your R34 GTT?
If so, what kind of work do you want done by them?
There's lots of shops I'd recommend for oil changes etc, but wouldn't let them come within 50 meters of the car if it was a turbo upgrade or head rebuild...
Keep in mind also, that every shop is going to have good and bad stories... Generally go with a workshop that's been around for a while, noone stays in business long if they don't know what they're doing and just generate constant bad rep...
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074020
Yeah I understand people are going to have good/bad, if the good out weighs the bad I may try them if there are no "horror" stories.
if someone compared them to OH Performance that used to be in Sunshine I'd steer well clear...
What are you looking to get done?
Looking for someone that can do everything or as much as possible.
I need a hi-flow cat and a new boost controller to start with, then I'll be looking at flex fuel and a retune to suit.
I've been to chasers (west) to get a knock from the previous owner fixed, came out just as bad... good waste of money that was. So then I tried RE Customs, they fixed the knock so I've been going there for services and got them to install an aftermarket turbo. No complaints about the work except its just too far. Takes me an hour and a half to two hours to get there in "light" traffic.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074077
Basic mechanical work like hi-flow cat's and a new boost controller installation can be done by nearly anyone... If you've got an aftermarket ECU though, it is WORTH spending the time travelling a little bit to go to a good tuner! Should only really need to be done only once or twice per year IF you keep modding throughout the year and plan out when it is going to need a new touch-up tiune.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074122
I know thanks. I'd get it all done at once instead of getting 5 tunes obviously.
Somewhere decent in the western suburbs would be nice though, whether a big or small job, as I said I'd prefer to take it to the same place so they know the car and what they've done.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074146
Edge is a great workshop, but they send a lot of their bigger welding jobs to me, not sure they have a permanent fabricator there at the moment.
I second this... chasers left a bad taste in my mouth. Edge motorworks will be under going some serious work on my r34 gtt sedan and shall be making well into the 300++ rwks by next week. They are professional, prompt and clean n chian is a wicked tuner
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7076482
Hope to see it there Rob, my Yellow evo is there for a stroker build. :)
Love Cihan's tuning and the way he explains any issues he's having with the car, I always leave happy... Well other than that one time I lifted the head during a run. :P
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7076521
I also know Barry and Kennan, ive known Kennan since he was a little kid riding his bike in my area.
Kennan breathes, eats and shits Nissans, when i take my stuff to Barry its only he and Kennan that i trust.
Barry is old school, very honest and down the line, ive watched him work carefully and he does things how i would have done them myself.
Thats why when im busy or there is no room in the garage to work, we send them our own cars.
Also their Dyno guy, Ghian is really good at what he does, one particular car from Sydney was sent to them, a Supra with the plates Gameon produced some really good figures....run in tune was 31psi, 7500 redline making 750Kw at the rears....i wont get into what it made on 3 bar......
They will be installing. running in and tuning our RB26/30 when the time comes.
I also noted a lot of RB28 strokers in his engine room being built right now between the 2JZ's.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7095730
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
