I'm assuming this is for your R34 GTT?
If so, what kind of work do you want done by them?
There's lots of shops I'd recommend for oil changes etc, but wouldn't let them come within 50 meters of the car if it was a turbo upgrade or head rebuild...
Keep in mind also, that every shop is going to have good and bad stories... Generally go with a workshop that's been around for a while, noone stays in business long if they don't know what they're doing and just generate constant bad rep...
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074020
Yeah I understand people are going to have good/bad, if the good out weighs the bad I may try them if there are no "horror" stories.
if someone compared them to OH Performance that used to be in Sunshine I'd steer well clear...
What are you looking to get done?
Looking for someone that can do everything or as much as possible.
I need a hi-flow cat and a new boost controller to start with, then I'll be looking at flex fuel and a retune to suit.
I've been to chasers (west) to get a knock from the previous owner fixed, came out just as bad... good waste of money that was. So then I tried RE Customs, they fixed the knock so I've been going there for services and got them to install an aftermarket turbo. No complaints about the work except its just too far. Takes me an hour and a half to two hours to get there in "light" traffic.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074077
Basic mechanical work like hi-flow cat's and a new boost controller installation can be done by nearly anyone... If you've got an aftermarket ECU though, it is WORTH spending the time travelling a little bit to go to a good tuner! Should only really need to be done only once or twice per year IF you keep modding throughout the year and plan out when it is going to need a new touch-up tiune.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074122
I know thanks. I'd get it all done at once instead of getting 5 tunes obviously.
Somewhere decent in the western suburbs would be nice though, whether a big or small job, as I said I'd prefer to take it to the same place so they know the car and what they've done.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074146
Edge is a great workshop, but they send a lot of their bigger welding jobs to me, not sure they have a permanent fabricator there at the moment.
I second this... chasers left a bad taste in my mouth. Edge motorworks will be under going some serious work on my r34 gtt sedan and shall be making well into the 300++ rwks by next week. They are professional, prompt and clean n chian is a wicked tuner
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7076482
Hope to see it there Rob, my Yellow evo is there for a stroker build. :)
Love Cihan's tuning and the way he explains any issues he's having with the car, I always leave happy... Well other than that one time I lifted the head during a run. :P
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7076521
I also know Barry and Kennan, ive known Kennan since he was a little kid riding his bike in my area.
Kennan breathes, eats and shits Nissans, when i take my stuff to Barry its only he and Kennan that i trust.
Barry is old school, very honest and down the line, ive watched him work carefully and he does things how i would have done them myself.
Thats why when im busy or there is no room in the garage to work, we send them our own cars.
Also their Dyno guy, Ghian is really good at what he does, one particular car from Sydney was sent to them, a Supra with the plates Gameon produced some really good figures....run in tune was 31psi, 7500 redline making 750Kw at the rears....i wont get into what it made on 3 bar......
They will be installing. running in and tuning our RB26/30 when the time comes.
I also noted a lot of RB28 strokers in his engine room being built right now between the 2JZ's.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7095730
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
