I'm assuming this is for your R34 GTT?
If so, what kind of work do you want done by them?
There's lots of shops I'd recommend for oil changes etc, but wouldn't let them come within 50 meters of the car if it was a turbo upgrade or head rebuild...
Keep in mind also, that every shop is going to have good and bad stories... Generally go with a workshop that's been around for a while, noone stays in business long if they don't know what they're doing and just generate constant bad rep...
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074020
Yeah I understand people are going to have good/bad, if the good out weighs the bad I may try them if there are no "horror" stories.
if someone compared them to OH Performance that used to be in Sunshine I'd steer well clear...
What are you looking to get done?
Looking for someone that can do everything or as much as possible.
I need a hi-flow cat and a new boost controller to start with, then I'll be looking at flex fuel and a retune to suit.
I've been to chasers (west) to get a knock from the previous owner fixed, came out just as bad... good waste of money that was. So then I tried RE Customs, they fixed the knock so I've been going there for services and got them to install an aftermarket turbo. No complaints about the work except its just too far. Takes me an hour and a half to two hours to get there in "light" traffic.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074077
Basic mechanical work like hi-flow cat's and a new boost controller installation can be done by nearly anyone... If you've got an aftermarket ECU though, it is WORTH spending the time travelling a little bit to go to a good tuner! Should only really need to be done only once or twice per year IF you keep modding throughout the year and plan out when it is going to need a new touch-up tiune.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074122
I know thanks. I'd get it all done at once instead of getting 5 tunes obviously.
Somewhere decent in the western suburbs would be nice though, whether a big or small job, as I said I'd prefer to take it to the same place so they know the car and what they've done.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074146
Edge is a great workshop, but they send a lot of their bigger welding jobs to me, not sure they have a permanent fabricator there at the moment.
I second this... chasers left a bad taste in my mouth. Edge motorworks will be under going some serious work on my r34 gtt sedan and shall be making well into the 300++ rwks by next week. They are professional, prompt and clean n chian is a wicked tuner
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7076482
Hope to see it there Rob, my Yellow evo is there for a stroker build. :)
Love Cihan's tuning and the way he explains any issues he's having with the car, I always leave happy... Well other than that one time I lifted the head during a run. :P
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7076521
I also know Barry and Kennan, ive known Kennan since he was a little kid riding his bike in my area.
Kennan breathes, eats and shits Nissans, when i take my stuff to Barry its only he and Kennan that i trust.
Barry is old school, very honest and down the line, ive watched him work carefully and he does things how i would have done them myself.
Thats why when im busy or there is no room in the garage to work, we send them our own cars.
Also their Dyno guy, Ghian is really good at what he does, one particular car from Sydney was sent to them, a Supra with the plates Gameon produced some really good figures....run in tune was 31psi, 7500 redline making 750Kw at the rears....i wont get into what it made on 3 bar......
They will be installing. running in and tuning our RB26/30 when the time comes.
I also noted a lot of RB28 strokers in his engine room being built right now between the 2JZ's.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7095730
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
