Hey Guys
I have a set of BBK Akebono brakes up for sale. They were on a v35 coupe so comes with the adaptors, the guy who took them off was very suprised at the quality of the adaptors and the condition of the brakes (i am not a mechanic), came off the car when it was going through compliance and i had bought them for a project but thats not happening now.
4 Pot Front and 2 Pot Rears (sorry im not sure about rotor sizes but if you search sau, you are sure to find them :) They are bloody huge though....
Comes with Rotors which are in near new condition (maybe) as there is not even an indication of that line on the edge of the rotors.
Brake Pads included and are about 80-90%...
The Brakes themselves are in very good nick, no leaks nothing.
Direct fit for V36 and Z34
Comes with adaptors to fit 350GT Coupe.
Asking $1800 ONO
Im in the country until this sat and going overseas for a month after that so i am after a quick clean sale.
Havent taken pics yet but happy to take and send to interested persons
Call 0414482636 or Pm
cheers
Amrit
PRICE DROP TO $1500 Firm IF AND ONLY IF SOLD BEFORE I HEAD OVERSEAS (27/10) or else they will be the old price as i wont be in a hurry to sell when i get back...
post-23808-0-90937500-1382497909_thumb.jpgpost-23808-0-94075300-1382497912_thumb.jpgpost-23808-0-46313200-1382497918_thumb.jpg
post-23808-0-70094600-1382497933_thumb.jpgpost-23808-0-03668800-1382497923_thumb.jpgpost-23808-0-12461700-1382497929_thumb.jpg
Here are some pictures and yes they are a lil dirty will do good with a nice clean up, the calipers and brake pads are in order of pictures (front caliper followed by front brake pad pic), they are in my car boot at the moment, can deliver around brisbane area if needed on or before this SATURDAY 27th Oct.
Cheers
Edited by AsM
Not meaning to be rude or anything but you can get the whole kit new delivered to your doorstep from Z1 in USA for $1,800
Edited by colin.ssc
Also for comparison, a set of Z33 Brembos (direct bolt on for the V35 Coupe) will only set you back $750 at the wreckers (Niss4x4 in VIC.)
Find me a set of Z33 brembos for $750 and i will buy them no questions asked...
@Colin, mate i wasnt aware you could get them $1800 delivered to the door, last time i had read it was costing ppl around 2500 landed and thats when the aussie dollar was high. cheers
How many sets do you want?
Call up Niss4x4 and arrange a Courier. You could easily have a set at your door for $800 (including delivery).
Yea it still cost around 2200, but Z1 does free delivery now. I was looking around and found that out. Only thing that's from USA...not too sure how people feel about that.
GLWS though....
Edited by colin.ssc
GLWS though....
I checked with them and the free delivery is for local USA only not international.......
Its an american company and theyre going to do free international postage.....yeah. Some people are stupid. Good price on these. If i wasnt doing a motor swap id smap them up. Good luck with sale mate!
Btw if anyone interested, these can be paid for and picked up in brisbane but wont be possible to post as im not there myself. If anyone is interested please send me a mesg here with your name and number and ill get a friend of mine to get in touch, cheers
When the dollar was stronger I purchased a new front & rear set with slotted rotors, callipers, pads, lines & adaptors from the states for around $2,300 landed.
If you can get int shipping for $300 your on a good wicket.
Last I checked a full set of 10 year old brembos off an r34gtr were going for $1500, which is why I went new aekbono's.
Around the $1500 mark for good nic set of aekbonos sounds decent.
BTW I had these on my v36s and that thing stopped on a dime.
Have you tried listing on zclub.com.au?
Edited by pauls
  • 4 weeks later...
  • 3 weeks later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
