Hey guys, a couple weeks ago I bought LED tail lights for my r34, I installed them, and the brake lights and blinkers worked, however the tail lights themselves didn't. I replaced the broken 10amp fuse with every fuse you can think of, and 30 amp is the only one that doesn't break, however the lights still wouldn't work with that in. I was only driving by day for a while, then switched my lights on, and now my blinkers have cut out. I don't want to spend hundreds on electrical work at a shop, so please if anyone knows how to fix this, it would be appreciated. Cheers.
https://www.sau.com.au/forums/topic/434087-electrical-problems/
I'd be more worried that LED's draw FARRRR less power then normal halogen lights. So if you are blowing fuses then you have a serious problem. But will agree with above. NEVER a good idea to just put bigger fuses in to 'see what happens' They are designed to be there to blow before other more expensive componenets fail, Fuses are there for protection.
unplug the lights and confirm voltage at the plug. Check for around 12V
Is it possible to plug the tail-lights in wrong or anything? I wouldnt think so if its anything like my LED lights, they just plug into the standard sockets and they will only really go one way.
I would contact the supplier and ask them if there is an issue. Maybe youve got a problem with a join somewhere and they might replace them. However now that you have upped the fuse rating, you may have burnt out something serious inside the lights and they might not warrant it.
Hey mate I got the same led lights for my 34 I ran into the same issue make sure they are in properly as in all the wires match up to where there meant to be I had a similar issue when I had mine first put in turns out the wires / plugs were not in properly see how you go with that
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
