Hey Brendan
  • You got your ride/s organised ?
  • Is this the right places ??
  • 5ish ok ?
Yes 5ish is good, we plan on getting to regatta at 5:15
THE PLAN (READ IF YOU'RE COMING):
  • For anyone that is meeting us at Isabella Plains, please come around 4 - 4:15. I'll be standing outside so you won't miss me, just look for the tall asian dude in a suit (btw my name is Brendan).
  • Cars meeting at regatta please be there around 5 - 5:15
  • We are going to lennox gardens to take photos after we meet at regatta. After that we should have enough time for a cruise
  • Around 6ish we are gonna rock up to ANU House in a rb train and make some serious noise lol
Just to clarify, the arrival space is very small and I'm not 100% sure that every single car can fit. There are no restrictions to the amount of cars but we seriously atm have a lot of cars coming. I'm sorry if not everyone can be in the arrival space, but we can figure something out. Another thing is, for people wondering I'm in year 10 and i'm sorry if you think I'm a little top bloke ahahaha :) There will also be some parents that will be taking photos.
Here is another map of the places that we are going to. This will probably change:
http://imgur.com/n2fOHFe
  • Like 1
Won't be able to make it with the 34.
Health deteriorated as of recent and I'm in and out of the hospital.
Sorry man
No good Tom - get better maate
GTR Judd & Jimmy S will be leaving from mine about 4:30 - Southside :thumbsup:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
