Hey Brendan
  • You got your ride/s organised ?
  • Is this the right places ??
  • 5ish ok ?
Yes 5ish is good, we plan on getting to regatta at 5:15
THE PLAN (READ IF YOU'RE COMING):
  • For anyone that is meeting us at Isabella Plains, please come around 4 - 4:15. I'll be standing outside so you won't miss me, just look for the tall asian dude in a suit (btw my name is Brendan).
  • Cars meeting at regatta please be there around 5 - 5:15
  • We are going to lennox gardens to take photos after we meet at regatta. After that we should have enough time for a cruise
  • Around 6ish we are gonna rock up to ANU House in a rb train and make some serious noise lol
Just to clarify, the arrival space is very small and I'm not 100% sure that every single car can fit. There are no restrictions to the amount of cars but we seriously atm have a lot of cars coming. I'm sorry if not everyone can be in the arrival space, but we can figure something out. Another thing is, for people wondering I'm in year 10 and i'm sorry if you think I'm a little top bloke ahahaha :) There will also be some parents that will be taking photos.
Here is another map of the places that we are going to. This will probably change:
http://imgur.com/n2fOHFe
  • Like 1
Won't be able to make it with the 34.
Health deteriorated as of recent and I'm in and out of the hospital.
Sorry man
No good Tom - get better maate
GTR Judd & Jimmy S will be leaving from mine about 4:30 - Southside :thumbsup:
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
