Hey all,
Looking at some Varrstoen es1 rims (BBS LM replicas) for my gtt, but I can't decide whether I want 18's or 19's.
My current setup is 18x9.5 +15 all round, with 255/35. The fronts sit pretty close to flush, while the rear guards definitely have room to accommodate a wider rim and tire.
**The most aggressive setup offered in 18's are: 18x10.5 +12
These will sit 16mm further out than current rims, with the inset having 10mm less clearance. (basically around 5mm poke at the front, rear's pretty flush I'd assume)
**The most aggressive setup offered in 19's are: 19x11 +12
These will sit 22mm further out than current rims, with the inset having 16mm less clearance. (around 11mm poke at the front, slight poke at the rear)
Seeing as the rims have a step lip, this usually makes them appear smaller, which is my argument for going with 19's, but that said I wouldn't be able to lower the car any more, and I think they will foul on the coilovers.
18's allow me to lower the car slightly to eliminate wheel to guard gap, and I'm a bit more confident on this fitment clearing everything.
OPINIONS AND COMMENTS!
https://www.sau.com.au/forums/topic/434208-18-or-19-inch-rims-on-r34-gtt/
I would go 18's on a GTT, 19's will be too hard to fit, The right rim will look nice whether it is 18 or 19.
You were the one with pumped guards yes? If the most aggressive offset isn't enough poke for you I would just run a hubcentric spacer, it will only be ~10mm anyway?
Yep, pumped rears, gtr fronts.
I've been thinking 18x10.5 +12 with a 265-275/35 on the rear. I'm sure this will look fine, but yeah if needed I'll run a bolt on.
Fronts will need some camber if I go a 265/35.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
