Hi all,
Interested in tricks from the experts on how to install / remove wheel nuts without scratching them?
Some people have said use painters tape on the nuts and it will take the wear, others have said cover them with a plastic bag..
Are there any tools that are easily sourced (from Supercheap, Repco - etc) which specialize in this?
Thanks in advance for any advice or info.
Cheers.
Edited by iwanta34gtr
stick a piece of rag in your socket, dont use impact wrench...
Yes, rayon/silk is thin enough, and as a footnote...
Sujith the Principal of Hornsby Tyrepower uses rags on his tyre changing equipment too when he sees quality rims.
And to protect the bore of the wheel from being scratched by the socket, you can get some large shrink wrap tube from JayCar and shrink it on; gives a slightly rubberized texture which won't chip or scratch the finish.
I used these gktech ones for over a year with no worries. Made of steel so very difficult to round off.
And it's not that hard to chuck the key in the glovebox is it ;)
Hi all, thanks for the advice.
I ended up taping the inside of the socket / tool so it didn't have direct metal on metal contact with the nuts.
Worked a treat.
Cheers.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
