May take you up on that Mitch. Base on the youtube vids I've seen and the documentation it looks pretty straight forward. I'm just making up the external map and wideband interface looms now.
I can't imagine Haltech would have left any surprises for me. Out of the box it should control the fuel pump speed and send the correct TPS signals to the Attessa right? Ive seen lots of other people have issues with these two simple things... Edit: Other ecu's of course... Wolf/vipec etc...
Edited by GTRNUR
High/low fuel pump control is hard set at 5% throttle opening (from memory). The TPS follower for the ATTESA 100% works as per factory, as does the injection duty signal to the MFD.
The pre-loaded base map should be enough for you to get started with. Just make sure you load the calibration for your MAP sensor, set your TPS limits, enter your injector characteristics and deadtimes and away you go. Set base timing (i like to lock the CAS all the way clockwise) by enabling the ignition lock and adjusting the trigger angle. Dont forget to set the engine capacity, and if you're running an ethanol blend of fuel without a flex sensor, deduct ~33% from your injection flow rate to allow for the fuel density difference. :cheers:
Not necessary, it just connects to Inj1. The MFD does the rest.
If you were able to program up an 7th injector channel, it would need to be configured to have the same output pulse width as all the other injectors. Also, you would need to put a load on the output, or a pull up resistor to +12v so the MFD would be able to read the variable PWM square wave.
Sorry no dyno time yet.
The Haltech is in now. It idles and revs. Didn't get a chance to drive it anywhere though, nor do anything but do the basic setup on the weekend.
With any luck I can take a day or two off later this week and spend some time on the phone with Mitch.
AI tell me my surge tank is still 2+ weeks away as well.
  • 2 months later...
More changes are still in the works. I've replaced the entire fuel system again after being talked into going down the E85 flex fuel path. So bigger injectors, more pumps, bigger fuel lines, external surge tank and bags of fittings...
It takes for ever to get parts up here too. Pay for overnight and it arrives 3+ days later.
I've yet to source and wire in a flex fuel sensor, and I've got locate a fuel cooler to mount behind the diff too.
The interesting news is that I hope to be getting Mercury Motorsports to come to Cairns to do the final tune and setup of the car. If anyone can get it to produce a good final result, I think they are certainly capable of it.
  • 1 month later...
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
