Car found last week, finally got a chance to look at. Pillar clusters, rims, spoiler, front grill, number plates and even the SAU stickers were taken. Generic shit put on.
The prick who took it had the decency to leave a Van Halen cd in the cd player so thanks f**kwit. Hoping the engine isn't screwed but considering my rear bumper is now full of carbon shit, I won't hold my breath.
Pictures speak for themselves:
+1, and if its sitting in the back of a factory somewhere and someone spots it as they're passing through and remembers the car from facebook / forums... A complete car which doesn't match the stolen car description won't raise eyebrows, but a half stripped car with the distinguishing features missing does
Or...burn the thing / drive into lake and not worry about turning it back to stock?
Cause the whole effort to return to stock obviously worked in keeping it from being found!
Wtf @ putting stock parts back on?
wow.. thats strange!
does this mean the person who stole it most likely owns a white r33 gtst also?
seen any snooping around?
To update the post, car was found around 4am near the CBD idling in the back streets when found by police.
After giving the car a once over, the prick who took it obviously thought he'd use it for a work car after he sold all the nicer bits. I found so much shit in the boot and back seat (work tools, paint, spare clothes - even a fkn porno). Who the hell steals a car and decides, "yep I'll keep this for myself" and drives it like he owns it?!?! Explains why the stock bits went on.
Car hasn't got any major damage on the body (except for missing bits) comp is fine across all cylinders but the turbo has shat itself, Unfortunately I think they'll write it off . :(
U reckon they'd write it off based on that? If it's just the turbo and some trim bits gone, I would think at worst maybe 3-4k of repair work necessary.
Started motor also gone, 18" wheels + rubber = $2k so around $6k as quoted by the inspection center.
  • 5 weeks later...
It pisses me off the amount of low life scum there is around knocking off vehicles I had a VL caiais stolen from crown about 10 years ago, luckly for me it was found the following day in cranbourne with only the sub and amp taken from it,
I was previously in the 4WD scene and the amount of Nissan Patrols that are getting knocked off in melb is unreal, every week one goes missing, if some prick ever tried to come to my place and knock off my pride and joy they would want to be quicker than a speeding bullet from a 30-06 rifle
Edited by vestvicr34
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
