I'm meeting up with 5hiv on Wednesday arvo to get a cat back exhaust fitted and some R34 rims.
At the same time ill probably try adjust the ride height or tackle that on the weekend.
Checked my child restraints and it looks like I only have one so ill probably grab those off you as well Rob. Not sure how they get fitted though?
If the car fails on too many things is it possible to cancel rego and re-rego in NSW? Or do the defects follow you?
I got f**ked at rego a few months ago... got done with window tint, wheel alignment, no child restraints, to low, to loud, wheel spacers, sub :/, not showing my middle seatbelt clip thing, lower ball joint exc... didn't get done with the turbo timer, pod filter, low brake pads, no engineers report for the child restraints witch Trojan did, they didn't check the Db of the exhaust on second check or the track... f**k they were assholes haha
if you get picked up on that just remove the front tint with a hair dryer...
I removed it all :/ getting the glue off the back window is a shit fight!
I wouldn't worry about it to much.. it sounds like you have all the skyline problems.. if you cant do some of the stuff yourself book it into Trojan, great people down there!
I got my standard shocks and ball joint from them for a good price...
Dunno if it was answered, only skimmed through - regarding the boot lining and struts, you'll be fine. I only had the plastic between the boot and the battery shelf, a sub held in place with tie downs, that's it. Also my struts might as well have not been there lol
Awesome, well I'm going to give it a shot because that doesn't hurt. But still can anyone give info on if I de-rego and then re-rego in NSW would I have any issues?
Only thinking because my parents live down the coast and there are plenty of workshops down there who would allow me to rego it. Could easily chuck it in my parents name for the next 3 months
will need blue slip here so depends on who you take it too will confirm how hard it is.
Just booked it in for the 12th of December :D
So I have some more time to hopefully receive my new car.
Had a chat with the bloke and he said if it fails the inspection then I have a month to get things sorted.
That should allow the time for my R34 to show up MAYBE.
  • Like 1
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
