Seven-time Formula 1 world champion Michael Schumacher is in hospital after suffering a head injury in a skiing accident.
The 44-year-old fell while skiing on unmarked slopes in the French Alps and hit his head on a rock.
He was attended to within minutes of the accident before being airlifted to Moutiers hospital.
Despite initial reports suggesting his injuries were serious it is believed that Schumacher, who was wearing a helmet, is not in a serious condition.
According to the Press Association, Gernignon Christophe Lecomte - director of the Meribel resort in which Schumacher was staying – told Radio Monte Carlo Sport that the ex-Ferrari and Mercedes racer was conscious, and was airlifted with 15 minutes of the accident.
The German's manager Sabine Kehm confirmed nobody else was involved in the fall, and was also quoted as saying: "Michael fell on his head when he was on a private skiing trip in the French Alps. He was taken to hospital and is receiving professional medical attention.
"We ask for understanding that we cannot give out continuous information about his health."
http://www.autosport.com/news/report.php/id/111978
'Tis likely that "Schu" will remain in a "permanent vegetative state" unless...
Dat penises nose though
The Chin could live with the step but buggered if he was driving a penis nose.
I've only ever seen a sketch of one bloke's interpretation (ie 'guess') of what the 2014 cars would look like that suggest they'll have a 'penis nose'. All the other guesses have been very different. I'd be willing to bet scarb's is miles off when the cars get unveilled.
Force India looks good. Can't see the nose yet though...
Last I heard before the family closed off communications with the outside world was he was still in a coma. Vegetative state is a different clinical state. "Permanent vegetative state" is certainly not what anyone has called it, because they don't use that term until the patient has been that way for about 1yr...
The truth of the situation isn't terribly optimistic, but spreading completely incorrect information is not helpful. This is about the best quality information (well speculation) we have since the family shut off communication to his many anxious fans:
http://formerf1doc.wordpress.com/2014/01/22/what-may-be-going-on-now-and-where-this-might-be-going-long-speculative-and-detailed/
for those that haven't seen check this out for a bit of detail about the engines for this year.
http://jalopnik.com/how-formula-ones-amazing-new-hybrid-turbo-engine-works-1506450399?utm_campaign=socialflow_jalopnik_facebook&utm_source=jalopnik_facebook&utm_medium=socialflow
is it just me or do these newest lot of regs spoil what could have been some incredible engineering?
They should just make it a regulation that the very tip of the nose cone had to be wider and it wouldn't look so bad? Eg tip of nose width must be 'X' mm wide or '85-90'% of the width 300mm from tip
Edited by Scottydoo
Formula 1 is to make another attempt to ban tyre warmers in 2015.
Previous efforts to introduce a ban have been scuppered because of safety concerns, amid worries from drivers about racing on cold tyres.
But as part of a raft of changes proposed for 2015, the FIA announced on Thursday that all forms of tyre heating devices will be outlawed.
The FIA has also ratified that the minimum weight of cars will increase by 10kg to 701kg in 2015 - which should help alleviate concerns that heavier drivers are put at a disadvantage.
http://www.autosport.com/news/report.php/id/112250
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
