So who's tipping what for the Malaysian GP?
I'm quietly thinking Mercedes are going to have an engine failure of some sort, something about Hamiltons interviews since Melbourne make it seem like he/they are not entirely confident with the engine he will be using
If Rosberg's has the same potential issue then being the engine that has done more km, there might be a problem with his car
Or they might walk away with this one again, who knows.
Will get to see some real power comparisons with the long Sepang straights at least. See how the Ferrari stacks up to the Merc, I think the Renault is behind so we will get to see that for sure or not as well
Hoping Ferrari have made a step forward, hope Kimi has a better run
Rosberg's worked which is a good start and maybe an indication it will continue to work. They only get five (?) per year so you would hope one gp hasnt knackered it.
Predicitng Ricciardo will continue to dominate his fragile team mate.*
Hoping the Caterhams qualify nowhere near the Williams.
*May have gone somewhat early with the domination call.
My money is on a very strong weekend by Williams. They generally go alright around there and then fall off the face of the planet until the end of the year.
Will be very interesting to see the racing as there are plenty of overtaiking opportunities at Sepang
Well you can always hope. Problem with teams going better than they should is they almost invariably find some way of stuffing it up. eg Bottas in the wall or it rains and they have no wet weather pace or some other random reliability thing that screws a good weekend.
Wish I could pocket a dollar for every time multi 21 gets trotted out this weekend.
f**k. Like I said, NOONE in here is going to decide what the outcome is. Its pointless arguing like this.....
Just wait till the f**king appeal and then everyone will know
f**k. Like you said, NOONE in here is going to decide what the outcome is. Its pointless discussing it like this.....
Just wait till the f**king race and then everyone will know
:P
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
