Left hospital or just woke from coma.
Too many differing reports.
Schumacher has been transferred to the University Hospital of Lausanne, the Swiss hospital confirmed on Monday (Sydney Morning Herald)
Moved to new hospital.
Edited by stR33ter
both mate.
Out of coma and hospital :)
Out of a coma doesn't mean that he is conscious, it just typically means that he is breathing for himself and responsive to external stimuli such as touch, whether there is higher brain function has not been revealed, as far as I have seen.
the coma was induced but they cut the medication to bring him out of the coma months ago... It's still obviously a massive positive that he's out of the coma now and has been moved from the Genova hospital.
Apparently when awake he is 'responsive', but the degree of that responsiveness has not been revealed. Highly unlikely to be the same after such a long coma, but there's no point speculating that he's a 'vegetable and will never see the light of day again' ffs
Michael Schumacher out of coma: 7-time world Formula One champion leaves Grenoble Hospital
Formula One champion Michael Schumacher is out of a coma and has left the French hospital where has been receiving treatment since his devastating ski accident in December, his spokeswoman said Monday.
In the surprise announcement, the retired racing star's spokeswoman, Sabine Kehm, said he had been transferred to a facility in Switzerland where he will continue his recovery.
"Michael has left the CHU Grenoble (hospital) to continue his long phase of rehabilitation. He is not in a coma anymore," Ms Kehm said.
"His family would like to explicitly thank all his treating doctors, nurses and therapists in Grenoble as well as the first aiders at the place of the accident, who did an excellent job in those first months."
The 45-year-old was transferred to a hospital in the Swiss city of Lausanne, hospital spokesman Darcy Christen later said, where the seven-time world champion will undergo further treatment.
"For the future we ask for understanding that his further rehabilitation will take place away from the public eye," Ms Kehm said.
No further information was released about Schumacher's condition, which has been kept under a tight lid since his accident in the French Alpine resort of Meribel on December 29.
He underwent two operations to remove life-threatening blood clots, before being placed into a medically induced coma.
His family announced at the end of January that drugs used to keep him in his deep sleep were being reduced with a view to bringing him back to consciousness, but few other details had filtered out since then.
Schumacher is well known for his love of adrenaline sports, and even after retiring from the high-risk world of racing, he kept pursuing other high-thrill hobbies as a pilot, an accomplished motorbike rider, parachutist, skier and mountain climber.
He survived a motorbike accident in Spain in 2009, during which he suffered head and neck injuries but was released from hospital after just five hours.
The accident on December 29 proved near fatal, but in several statements released to the media, his wife Corinna and two children said they remained confident that the man who defied death more than once on the track would pull through.
In Monday's statement, Ms Kehm said Schumacher's family wanted "to thank all the people who have sent Michael all the many good wishes".
"We are sure it helped him."
Yep, he's out of a coma. Pretty safe to say that it'll be years before he's ever at another f1 event, if he ever makes it to one again. His head injury was bad enough that they put him in a coma. That has to say something about the extent of his injuries and the sort of condition he will be in. I think that if his condition wasn't so bad then there'd be more news and would've been more updates over the past 6 months.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
