As delusional as Maldanado this bloke.
http://www.planetf1.com/driver/18227/9487921/JEV-I-showed-my-potential
Scrappiest of races with penalities, running off the road left right and centre...yet is claiming it as his arrival drive. Where did he qualify again? :) Hack. Off you go to Nissan LMP1 program and leave Romain to fly the F1 flag
obvious troll is obvious
I'm just going to leave this here:
Last 2 races:
Singapore
12 13 Pastor Maldonado Lotus-Renault 60 +66.9 secs 18
13 8 Romain Grosjean Lotus-Renault 60 +68.0 secs 16
Italy
14 13 Pastor Maldonado Lotus-Renault 52 +1 Lap 16
15 99 Adrian Sutil Sauber-Ferrari 52 +1 Lap 14
16 8 Romain Grosjean Lotus-Renault 52 +1 Lap 17
what's that saying? "you're only as good as your last race", or in this case two lol
Edited by hrd-hr30
hmmm,
a "foreign substance" contaminated the electronic circuits in his steering column...
then a later tweet says
the contaminant was a substance used in normal pre-event servicing of the component.
dodgy. If it was a nomal substance used in normal servicing, why would you call it a foreign substance/contaminant? Funny how this normal substance used in normal pre-event servicing only found it's way into the electronics immediately as the cars rolled out for the race, not at the start of the event.
f**k it, i had to listen to years of Webber conspiracy theorists! :P
hmmm,
What substance would you use to "service" a wiring loom that would potentially contaminate the electronics that the loom plugs in to?
Think hair gel is a more believable explanation.
    • Haha no I'll do that one tomorrow. I've been ignoring it. It's the 5.0 one I'm taking about. (There is a little X to hide the 4.7 one if you want)
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
