Hope bianchi is ok, but I can't really understand how it could've happened. Well I can, but there should've been double waved yellows slowing the drivers down.
Jones is a fkn nugget though. "I can't understand why the jcb was there.....". Cause it was removing a crashed car so another car couldn't hit it. Unfortunately the worst happened and another car came off and hit the jcb.
pretty sure he meant the race should have been under safety car before it went out as that corner is pretty fast. fairly certain he continued and said something about that
More HP...who cares if they die...but then something happens and they're all about making f1 safer. Can't have it both ways I guess.
JEV in the points again... He's probably got twice the points of Kyvat, I stand by my point that he must not be a likeable person.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
