A hot lap with kimi in a f12 Ferrari.
Made me lol.
What a spanker of a journo. "Not the fastest way around the track...but loads of fun" :(
I would be screaming "Farking stick it to it . YEEEAAAAAAAAAAAAAHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!" Cow bell. Cow bell. Cow bell!!!!!
  • Like 1
http://m.speedcafe.com/2014/11/18/ten-foxtel-set-share-f1-rights-2016/
Could be interesting, I hope they don't go the way of v8 supercars and put most of it on foxtel.
Good, the less sport that FTA airs the better.
Then again I haven't watched the F1 on FTA for years, download and watch around 6 hours of coverage per GP compared to the 3hrs that Ch10 airs, not to mention the downloads are *available* in 720 or 1080p compared with Ch10's 576i.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
