http://m.speedcafe.com/2014/11/18/ten-foxtel-set-share-f1-rights-2016/
Could be interesting, I hope they don't go the way of v8 supercars and put most of it on foxtel.
Thank f**k for that. I hope channel 10 lose it completely
qualifying exclusive to Foxtel, races broadcast on both according to an article I saw yesterday. Doesn't really matter - just stream qualifying.
I'll be getting Foxtel just for this... Was already going to get it for next years motoGP season, but this just makes it an even easier decision. I'm guessing the foxtel coverage will pretty much be a direct feed of the UK broadcast, either Sky or BBC, and won't have ad breaks during the race...can't wait :)
  • Like 1
McLaren is planning on completing its first official test with its Honda power unit during the two days of testing following the Abu Dhabi Grand Prix.
Read more at http://en.espnf1.com/f1/motorsport/story/184393.html#Lg4CHeMPkH8KF1SY.99
Formula 1 boss Bernie Ecclestone has handed financially-troubled team Caterham a boost as they return to the grid at the Abu Dhabi Grand Prix.
http://m.bbc.com/sport/formula1/30116227
Yep apart from the MotoGP and AFL, Foxtel really has nothing to offer. If they had any sort of competition they'd be out of business by now.
Well they really need new subscribers because Netflix is going to kick them in the arse quite badly here i'd wager.
Yeah that's what I was getting at...They offer nothing....Their ads run longer than FTA TV, and contain plenty of product advertisement, not just ads for other shows on Foxtel etc.
I remember when I was young and my parents first got it, the ads would run for literally 15 seconds, if that, and were solely to tell you what was coming up next or what was on another channel etc. In my opinion, you pay for the service so that ads aren't needed to pay the bills.. Foxtel has thrown that out the window, all while increasing prices at the same time..
I will get it for the MotoGP/F1/AFL next year, but I'll hate myself inside for contributing to the cocksuckers at Foxtel.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
