Cool idea. Nice to see something like this over there. 89 R32 GTR can be imported to the states this year...... :woot:
thanks man!, and hey , how are those ID1000 treating you? im thinking about getting those as well as a twin feed fuel rail.
Okay Ive got a couple of questions for you guys that know your stuff.
1. I have no idea where this goes to, i think its for one of the lines that goes to the carbon canister but ive got rid of all of the hardlines on the rb as well as the two that was for the carbon canister. Can this just be capped off? or left open? and what are the effects..its only on this one itb and it doesnt look as if it goes to the valves...
2.Has anyone seen this setup before? looks like it goes to the balance tube. but...theres three plugs? and if it does or doesnt go to the balance tube. what do people who get an fittings for their valve cover do with the port on the balance tube that has a restrictor that came from one of the ports of the valve cover..looks like it was for blowby maybe? idk.
c6b72d72-0e8e-4ecd-833f-7c5b2c2fb924_zps
  • 1 month later...
Well, if anyones wondering why i haven't posted in a while , its cause i took my engine apart...you know just to double check on some things and was not happy with what i found ..whoever had it before, wasnt taking good care of it. Feast your eyes lol
photo3-3_zpsebef457a.jpgphoto2-3_zpsa4ba8764.jpgphoto1-3_zpsd0400fc9.jpgphoto4_zpse4048fbe.jpgphoto2_zpsde44d33b.jpgphoto4-1_zpsd5289c10.jpgphoto3-1_zps20241fa3.jpgphoto2-1_zps7d2855eb.jpgphoto5-2_zpsc3dfaac4.jpgphoto4-2_zpsf7ca5e60.jpgphoto3-2_zps159d2b15.jpgphoto2-2_zps6fb18eb1.jpgphoto1-2_zps53d4d0e3.jpgphoto5-3_zps83591d65.jpgphoto4-3_zps8239065d.jpg
SO, after seeing all that, where i'm at right now is getting the head and block machined and cleaned etc, bore to 86.5 most likely after seeing those cly walls just to be safe..anyone have any specific things i should have done to the block/head as far as machining and cleaning etc that has to be done at a machine shop? much appreciated
Sorry for the late reply. The ID1000 are fantastic. Idle perfect and have never missed a beat. Highly recommend.
If you don't mind me asking, what kind of rail are you running ?
Well that's f**ked.
I'd be getting a thorough inspection on that head by looking at those valves. Also make sure you get all the oil galleries enlarged.
Wouldn't getting the oil galleries enlarged lower my oil pressure? Why would I want to enlarge them?
I run ID1000's too on the stock rail. Been in there for the last year without an issue.
tempting.. i do still have my stock rail, but i dont know. i think im just going to go aftermarket. Ive already dropped my fuel tank and tossed all the stock hardlines for fuel so i need a fuel rail that implements an lines. running an lines all the way back to fuel cell.
If you want 600HP you will need a bigger fuel rail. They are not expensive and worth the upgrade. And they look better :yes:
Yeah, ive been looking at this RawBrokerage Twin feed fuel Rail with ID1000 injectors. will more then likely go that route. and dam right, they look better lmao
  • Like 1
Yeah just do that. Job done :thumbsup:
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
