Looking at those times, anything under a 1:30 is quick, is that a fair comment.
As an idicator, what would be a good lap time for a well driven std tubo and basic susp upgrade R33 GTST with Type R rubber and no speed limiter around Sandown...also Winton if anyone knows
I would agree that anything under 1.30 would be a decent car with a competent driver . As a guide the quickest standard class WRX ( use of azenis tyres allowed) ran in the 1.30's and the driver of this vehicle is very quick. I would hope/expect that a well driven GTS r33 would/should be able to match these times. The R33 was well off the pace that day so most likely had some mechanical dramas.
adam
When I first went to Sandown I was told that anything under 1.30 was fast. I know at Phillip Island the time to get is anything under 2.00. NFI about Winton yet.
I know Donald ran 1.24's at Sandown in a 200sx which only has suspension and brake mods (and a big wang) on the weekend. Thats impressive.
Ah yes...that R33 was me
It was my first time on a track let alone Sandown all together, so no need to judge or speculate on my times
I didnt really attend this track day to go all out and cut some times or break records, more so just want to enjoy a bit of a fang on a track
So i was pretty suprised that i actually got a 1:39 on that day, as at no stage was i REALLY pushing the cars nor my own limits
Near the end of the day i realised there were a couple of corners i could have carried alot more speed in but by this time had a couple of problems
1. my inner wheel plastic arches decided to rip off, so i pulled off the track after the practice lap to take them off
2. on the last session, people reported seeing burnt oil out the back of the car, and i was loosing boost pressure
Anyway, its not good...cylinder 2 is down to 70psi compression :D
Taking the head off this week to fear the wrost
itll be good to see MORE people with R33 gtsts on a track, instead of being street heros
come on guys! its VERY addictive and cant wait to get the engine prepped up for more
Good to see the latest speed junkie join the ranks!
Hey maybe we should have some group theapy sessions or something?
"Hi my name is Snowman and Im addicted to track days. I had my first hit in Feburary and at the time I was just doing it for a bit of fun. But now if I don't get that speed hit that only the Track can offer I start to shake. I've tried burning a few HSV's at the lights but the hit just isn't the same. But I find comfort in knowing there is others like me out there."
whistla , wasnt having a go about the times i realised you where a novice with a car not running right. Im guessing you are a member of PIARC or similiar? , its always good to see other makes of car besides WRX's ( i had the RS in the avater) but i usually race a VL 5ltr (spun bearing atm) at all the rex events as they are very well run and organised . I was planning to come up and say hi but had a few things on the day to do .
adam
Nah thats cool
The car was running fine untill the last session...
I just wasnt full throttling on the straights during the start of the day as i was still getting the feel of the whole thing and letting people pass me. i didnt want to be pushed into the corners and prefer to tail people than be tailed
My confidenced gain near the end and really cant wait to get back on the track...
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
