Hey lad's after finally getting my car going after almost 4 years I thought it's about time I celebrated by taking it out to Basky for a lash.
Obviously Christmas is a busy time and I certainly don't have the time off but I was thinking of something in January maybe Australia day as I know that's been done before in years past.
Anyway I was wondering if there was anyone keen to come out and have a bit of fun and talk some Import shit cause I've been pretty dry for too long now.
Just a no pressure cruzy day and I'm sure we could organize some snags in bread for lunch if anybody else is keen otherwise I'll just make myself a sandwhich.
Edited by trustr32
https://www.sau.com.au/forums/topic/435992-januaryaustralia-day-track-day/
  • 1 month later...
Yep Like Funz has said above.
after the death of a driver at a private practice day in QLD last year.
you are now required to have a CAMS official present at all CAMS race tracks, it'll be a pain in the arse for a few years until,
we get a few younger guys trained up top do the job.
Cheers
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
