Ok so I have brought a Weldon speed pump controller to try and quieten down my Weldon 2025 pump
The controller says it is PWM controlled but the wiring diagram shows it as a closed circuit with a POT dial to preset pump speed and a toggle switch for race mod
I want to hook it up to one of the spare PWM outputs of the computer and let the computer run the controller automatically
Has anyone used or hooked up the Weldon 14000 speed controller and be able to tell me which terminal on the controller to hook into for the computer output ?
https://www.sau.com.au/forums/topic/436068-weldon-14000-pump-speed-controller/
It's not quite as simple as that...
Best you could do without getting super trickery would be to use an analogue output, set up as a load/rpm/boost switch to provide ground to the controller in place of the 'race switch'.
The computer I have has a fuel pump strategy already built in but it runs though the fuel or IGN out puts as a PWM
I have had a email from Jim at weldon telling me it will not take a PWM input an I don't have any analog outputs left( I don't think anyway) so what I was looking at doing is getting a 12v map sensor as the reference input instead of the potentiometer then have the computer set a 12v output to turn on "race" mode when the car goes over 21psi boost ( low boost is 19-20 )
The Hobbs is on/off, where a map sensor signal increases with boost which will increase pump speed as it climbs, basically an automatic potentiometer, the input of the controller is a variable, the more voltage inputted the faster the pump spins
Though you could use the Hobbs to trigger "race" mode
Sounds entirely to much f-ing around for veeeeery precise fuel pump speed control.
Any particular reason you wan't this level of control over your fuel pump? I would have thought 2 speeds would be more than sufficient.
To mee it seems like alot of effort for little to no gain, another system that gets needlessly complicated and can have catastrophic consequences...
... personally, I like knowing my 2345a is running flat out and that the fuel will be there when I need it.
PS fuel lab is shiiit, Weldon is best!!! ha ha ha
realistically the OEM fuel pump speed is on/off by nature... at idle and low rpm its spinning at a lower speed then as soon as it gets over a set rpm it ramps up to a higher voltage. This is what i would be setting up with the after market pump...
the pump is awesome piece of gear, just very very............very loud, and given it is a street driven car I want to make it as quiet as possible so when sitting at traffic lights I'm not getting to much attention, in a blue R34 GTR :whistling:
we had it on the dyno the other day and the fuel circulated so fast it just heated up the surge tank, but then that could have also been because the intank E85 pump wasn't working
the controller is just a little less flexible then I wound have though and when I looked in to the controller it said it was a PWM unit but no where I found said it wouldn't take PWM input
and did I mention the pump is VERY loud, louder then the 4" exhaust
that's right and I can do this with the Weldon controller, but my computer is set to run full variable so I can set it to run at any set level at any given RPM/load so I can set it up to run the pump at say 10% more flow then needed through the whole rev range
so when sitting at traffic lights or in a car park the pump is barely turning meaning I'm not just pumping fuel through the motor back to the surge tank heating the surge tank up
for what its worth i run 2x 044 as mains with a walbro lift, fuel circulates at constant voltage to the pump. i also have fuel pressure sensors and temp sensor in rail and surge tank... never see fuel temp rise above 35 degrees max with e85, no fuel cooler
That was going to be my setup till I was told 044 prefer to be gravity feed and my setup wouldn't allow for that so I went the 2025
I have the Walbro E85 intank as a lift pump which flows 500L/H 0-30psi feeding the surge tank and the Weldon which flow 590L/H@ 80psi and 620@ 50 psi, the 044 @ 80 psi flow 260L/H
Slowing the fuel down isn't really that big of an issue as I drove the car for the first time last night with the new setup and after 45min drive the surge tank was just warm but the noise, I have to do something about that which is the main reason for slowing the pump down
I have fuel pressure and temp sensors also, I'll have to go into the logs an see what the temp got to
I went to MSCN to buy the pumps and a bracket told them what I was doing with them and they told me not to do that with the 044s putting them selves out of a sale, so given that I'd tend to believe what they said
I then mentioned it to my tuner and he backed them saying the same, 044s should be gravity feed, both company's sell 044s neither sell Weldon and both told me for my setup go Weldon or Aeromotive
044s like to pump fuel not pull fuel, thats just what I was told
In my opinion weldon make some of the best fuel pumps available... from a delivery, engineering and reliability standpoint. Much better option than multiple o44's.
Yeah they are a bit loud, I put mine in a sound resistant case for long trips.
I've always been a big believer in single pump arrangements...
I'll PM you with a solution.
Cheers
Justin
Cheers
Justin
We use the 2033-A pump as a lift pump in the race car and it is quite loud!
We had a few lift pump problems with running methanol. So far the Weldon pump is proving its worth nicely, if its reliable then the noise isn't important, at least in a racing environment.
Thought of Weldon after reading a few of your posts about these pumps Justin. They are top notch!
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
