hey guys, i know all the RB motors have the slight boost leak from the back of the rocker covers from the gasket, just wondering how you would get rid of it? could you drop a front mount cooler in and that will eliminate the boost leak?
https://www.sau.com.au/forums/topic/436079-boost-leak-from-the-rb-motors/
Erm. . What?
To eliminate boost leaks you need to eliminate the chance of boost being forced out of the areas that inevitably leak, such as your rocker cover gasket (very prone to boost leaks these little bastards).
The problem lies in the intercooler itself, despite what you may think, the intercooler actually exacerbates your cam cover boost leak mate. When the intercooler fills up with boost, it enters the engine but because there is still an entire intercooler filled with boost, where do you think the excess boost goes? Exactly. Right out the cam cover and into the atmosphere.
To stop this, you simply get rid of the intercooler(s). Leave the intercoolers for the N/A cars, they're good for absolutely nothing on a turbocharged vehicle. By getting rid of your intercooler you have less lag and less built up pressure to to wreak havoc on those poorly designed cam covers.
So go to autobarn or repco, or even chop your neighbours kids' trampoline up and make some turbo piping. Route the piping from the turbo straight to the throttle body. Less lag, less pressure on your cam covers, more customz, more bitches.
Simple as that.
  • Like 3
You all don't know what your on about. The BIGGEST boost leak on an RB is from the little black round container behind the LEFT headlight, the charcoal canister. While eliminating the intercooler will fix the cam cover leak, eliminating the charcoal canister will stop the over fuelling.
You see, when the turbo comes on (boost leaks from the cam covers at this point), boost pushes through the charcoal canister (which filters the boost & mixes with fuel vapour) through to your fuel tank to pressurize it, which makes the turbo REALLY REALLY laggy.
Also sends turbo pressure to the fuel tank to push fuel into the engine on boost as the fuel pump alone isn't enough.
Thanks why on some cars you get a WHOOOSH noise when you open the fuel cap.
Ahhhh my car doesn't go whoosh, does that mean I need to mount a turbo in the boot just for the petrol tank?
I must be doing it wrong because mine doesn't do this. Does this mean I need a new engine?
I was thinking of upgrading from the RB25 to one of those SR20's anways
dafaq?
You know on the charcoal canister there's a valve that stops pressure from going into the canister when there's +ve pressure on the manifold.
Fuel tank is not pressurised on boost, who the hell told you this?
dafaq?
:domokun:
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
