yep kind of looks that way...guy buy stuff off ebay, realises it needs some major tuning and gives up on it...
please dont say its running a stock ecu....
It's an awesome microtech bro!
must have a seriously big spring in it if it wasnt opening before...
There was no vacuum/pressure lines to it before, so it wasn't opening at all, nor was it controlling the boost as he has said.
Now he connected it up by running vacuum/pressure lines to it, and it is opening, but dumping straight to atmosphere.
  • Like 1
No pressure source, it won't really open.
My 14PSI gate won't open without a pressure source on it.
And I'm betting it's a stock ECU... Since everythign else sounds stock...
Oh god... A microtec...
Pull your ebay turbo off, pull the looking like aftermarket manifold off.
Shove it and the microtec on ebay.
Buy a standard exhaust manifold, and purchase a stao high flow with Adaptronic ECU.
Reliable turbo, fixed up exhaust system + decent ECU all done quickly and easily.
Don't waste money tuning it twice.
  • Like 1
Oh rajab... A microtec...
probably the most solid advice i've heard. Waiting for money to come in before i can make such a drastic build though, baby steps. Any suggestions on turbo models for rb25det?
Edited by iTwix
Lets pretend you didn't ask that, to save more flaming.
Read up.
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/
As per the original post & subsequent post relating to '2007' rego sticker on the windscreen, as mentioned, I hope your for your sake & the rest of us enthusiasts here that you actually have registration & insurance on that thing...........
are you srs.. :| Ofcourse it's rego'd w/ insurence. -.-
plumb the wastegate back into the exhaust and it will be quiet again, are you running a stock turbo cause it sounds like it..
LOL
Seriously you put a screamer pipe on your car and are wondering why it is too loud? Maybe the above suggestion is a good one.
edit: You drove it without the wastegate hooked up? You are lucky you still have an engine, surprised it didn't blow up from overboosting, you need to get it tuned asap because it could be pinging it's tits off.
edit2: holy shit you don't even have a screamer pipe you were just venting it open in the atmosphere??? Suprised you didn't cause an engine fire, you've probably destroyed all your rubber hoses now. Stop driving the car!
microtech lt-12
Worlds worst ECU, get a stock ECU with nistune or something half decent.
Seriously save up a few grand, get the wastegate plumbed back into the exhaust, then get a proper ECU tuned, if you haven't already you WILL destroy the engine and your engine bay driving it like this.
Counting down the minutes until you burn the car to the ground or put a rod through the block, can't be more than a week away now.
How did it pass RWC in that condition??
Edited by Rolls
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
