I finished putting my bottom end together yesterday but it wasn't till I'd finished and turned the engine around to look at the top that I realised how far the peak of the pistons protrude out of the block.
Has anyone done a high comp RB and seen that amount of piston out of the block? Obviously I'll find out when I sit the head on but is there enough combustion chamber to even fit that much protrusion??
The pistons are custom CP 9.5:1.
I'd appreciate some input!
Ok cool. I googled images but couldn't find any decent shots showing so much protrusion.
I'll gently sit the head on when I get a chance and I'll soon know. I'll be nervous as all hell the first time I turn it over with the cam belt on!
Thanks for the responses guys, giving me a little bit of hope!
Thanks god it's got the valve reliefs in the pistons cause I think it's going to need that extra 1mm of clearance!
As a trial engine, I'm running RB25 pistons with the deck skimmed 30 thou to get them up flush with the deck. Also gives 9.5:1 compression and I have a similar amount of piston sticking up past the block as you do so I think you'll be fine.
To get 9.5:1 on an RB30 bottom end with an RB25/26 head you're running about the same amount of piston dome as a standard RB25/26 so you shouldn't have any issues.
Fit the head on with a few weak mockup valve springs and the cams your running to the correct valve clearance, use a old known thickness HG, put some plasticine on the pistons, fit cam belt on and very gently turn the engine over by hand for 2 full turns feeling for binding.
You want about 60 thou or 1.5mm valve to piston minimum clearance, better 80 thou or 2mm, any less than that is very dangerous and you might have them meet at high RPM....more clearance the better to allow for rod stretch and valve float.
As a trial engine, I'm running RB25 pistons with the deck skimmed 30 thou to get them up flush with the deck. Also gives 9.5:1 compression and I have a similar amount of piston sticking up past the block as you do so I think you'll be fine. this is what I have done, RB25 14cc dome tops with 26 head and 9.53:1, no issues yet and the engine has been running since January
To get 9.5:1 on an RB30 bottom end with an RB25/26 head you're running about the same amount of piston dome as a standard RB25/26 so you shouldn't have any issues. there is actually more clearance with the 30 bottom end then the 25/26, cause 500cc getting compressed at 9.5 parts to 1 means 1 is a bigger area then 428cc getting compressed 9.5 to 1
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
