Seriously WTF @ so many Skylines getting stolen in VIC. What's the point in dumping thousands of $$$ into these only to have it stolen? Might have to sell up and buy a XR6T. Pull off the 'turbo' badge and it will be essentially theft-proof compared to a skyline :wacko:.
  • Like 1
Bad luck mate, shame that you only had it for a week. Hopefully not too much money was put into yet, though that doesn't help much if there's an emotional bound to it. I've had two stolen in the past 12 months. Sadly as a result I've moved on from Skylines for the time being. Can't wait to get back in the game though.
  • 3 weeks later...
Dunno why they'd want the interior...it's all on upside down.
In seriousness, sucks to hear it was stolen. Hopefully not too much damage was done by them.
Still waiting to found out how much damage has been done. police will not release the car to me or tell me where it is until they are done with the investigation, all they said to me is it will cost me per day they have it and plus the tow
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
