yeah its got twin cats...... "cats"
you can see the too small cat looking objects where the cat would go, they are actually too small race mufflers i got from the states, they straight though and basically do nothing, buttttt they look pritty catty if u ask me.
yeah Micheal when race pace told me they wanted 6k+ for a mild steel twin 3 into 4...... kinda thought to myself......... "f it, im buying a tig.
cost me bugger all.... and i got a tig now too.
now to get the thing up on jezza's dyno, give her a drink of E85 and pull the lines off the acutators :yes:
  • Like 2
its easy man, everyone makes out its some big deal. get onto Tokentools buy yourself a welder. find a speedgas outlet so u can buy your own bottles and not pay rent.
set yourself up a good bench that the work peace will earth too. Make sure everything is always clean......... spark her up and lay beads. before you know it, you can tig : D
  • Like 1
yea mate, the two v bands are on outlet sides of the "cats".
theres only really 4 bends in the hole thing and 2 get used in that merge from twin 3 into 4. Everything eles is lobster backed and holyshit there was alot of cuts. The whole system is no more than 5mm off the floor pan of the car, its as tight up as it can be.
So everytime i came across an area i could pick it up a few mm here and there id lobster back it so it all stayed as close as possible...... ground clearance, i like my car low. : D
all the pipe work, the 2 normal flanges, and the 4 bends i got off Jez his got contacts :D
the V bands and the 2 "cats" came from summit in the states
The mufflers AES
all up cost, around $1400 including, tig consumables. 1 bottle of Gas, and Re-flecta Gold heat tape to go on the floor pan where the exhaust runs..... just so i dont any fire issues
I got a HKS Super Dragger rear cannon which is 8" round, cut it up and opened it out to 4" using rolled SS perforated sheet wrapped with inox and packed it with GTB with one end of the SS perf tube slipped over the 4" pipe but not welded to allow for growth
Then headed over to Windsor exhaust where I got a twin 3" or 3.5" ( I can't believe I forgot wht size it is :( )with twin 5" bodied cats ( yes real working cats :) ) into single 4" mid muffler through to my backyard jobby rear muffler, all in coated mild steel cause I believe mild steel is quieter then SS as it lets the sound out the whole way instead of just out the rear end, its just what I believe doesn't mean I'm right :D
Deano, nice work, where you joined the two 3" pipes into the single 4" is that two 90deg bends welded together then a 4" hole cut in and 4" pipe welded onto it ?
What sort of coin is that gold tape worth? I have a spot where the front pipes get close to the body.... and melted my carpet :\ haha
I got some of the silver version for around $40 for 24" x 24" for where my exhaust gets a bit close to the surge tank, I have some left over if you want it and if its enough :)
Most motor bike shops have some stuff that will happily live touching the exhaust, they use it for the plastic flaring when it is to close to the exhaust
cheers mick, the merge into the 4inch is 2 30deg bends notched i basicly drew it on the ground the shape and width i wanted the two pipes to be apart. than eyed em off the pic i drew onto the pipework..... than chop chop.
than sqeezed down the 4inch so it was 3inch at the very end and welded it out.
when u look up the 4inch into the where the 3 3inch pipes are merging, you can see a straight line right though the bend doesnt really affect the flow...... one way or the other the exhaust is heading in that direction and theres plenty of room for it.
also gotta remember as the exhaust cools down it doesnt need as much area. hence 3inch into 4inch i feel is a good combo, the 3inch gives you ground clearance and also heaps of flow in the hot parts of the exhuast. Its also quieter.
Mild is quieter than stainless but also a deeper note, so it makes more drowny sounds. Stainless is also lighter than mild, less dense.
not that i care to much about the weight, but all in all its not really that heavy for what it is. ill just have to run 1 extra psi of boost to compensate. hahahaha
the gold stuff piggaz was about $110 bux from the states for a 600mm x 600mm sheet...... thats 1 full sheet in that pic
Edited by Deano 1
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
