Complete car, Series 1 R33 gtst
I bought it for the gear box everything is for sale make offers
Ill compression test the motor tommorow
Things that have been sold are:
Brake master band booster
Gear box
Stuff for sale
Diff 200
Rims 100
Head lights 120
Bonnet 120
Ic kit 130
Radiator 110
Brakes 300 front and rear
Hubs 100 a pair
Cool boot lip wing 180
Exhaust 150
Cat 50
Dump pipe 50
Front bar 100
Door 80
Key set 120 for all of them
Anything else just ask
Located lower blue mountains Sydney
Pete
0448468884
post-219-0-35702600-1389432194_thumb.jpgpost-219-0-67510500-1389432223_thumb.jpgpost-219-0-47239100-1389432277_thumb.jpgpost-219-0-38669100-1389432306_thumb.jpgpost-219-0-87327200-1389432333_thumb.jpgpost-219-0-84354100-1389432379_thumb.jpgpost-219-0-16352500-1389432412_thumb.jpgpost-219-0-87648800-1389432449_thumb.jpgpost-219-0-91937900-1389432477_thumb.jpgpost-219-0-26644300-1389432520_thumb.jpg
https://www.sau.com.au/forums/topic/437439-r33-gts-t-wrecking-series-1/
  • Replies 42
Posted Images
Condition on rims and tyres?
Rears are rs and fronts are 50%
Some genius rattle canned the rims black so they look average
Let me know how comp on the motor comes out. How many kms on it?
Compression was good but a lad turned up and bought it this morning
Also the following has sold
Engine
Front bar
Boot struts
Engine and heater box
Gauges
Everything else is still available
Will you post brakes at buyers expense?
what knob is it?
That's a dangerous question round these parts.
Are the castor rod brackets available?
They will be once I start pulling it apart. Will let you know
How much for the skirts and rear pod (if the driver side is unsalvageable)?
Driver side pod actually looks ok. Not cracked, just a couple of surface marks. $140 if you're local and want to come pull them off yourself or $200 if I have to remove myself and ship them.
I want the Rear water squirter/jet!! PM me with a price including postage
Pm coming your way
Righto, the following parts are sold:
Engine, front bar, brakes, ic and piping, gear knob, boot struts, rear washer, dump pipe, gauges, suspension, ecu, brake master and booster, heater box
everything else still for sale!
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
