Unless your chasing massive HP then don't unless your cylinder wall are stuff.
Generally sleeving gives more strenght when quality sleeves are used and fitted by a competant machine shop"rare"
There are quite a few big hp rb26 running around with sleeve, but most of them aren't into discussing about what they've done.
Talk to a machine good shop and see their view.
I don`t have a block at the moment. The one from my car has nice big holes in both sides. The problem is finding a block that is still at standard bore or a maximum of 0.5mm over. I am chasing around 700 flywheel hp from this engine so do not want a block that is over 86.5mm bore.
Cheers, Dror
Sydneykid,
Have you not had any problems at this power level with a block overbored that far? I had been warned that the cylinder walls would crack at this sort of power.
Cheers, Dror
Only done 11 engines that bore size, no problems so far. :D
We have seen 87mm bore RB26s with cracks .we use std or .5mm over bore in very high powered RBs.We use new blocks when the budget allows at a cost of around 2k but remember that much of the machining is already done so some cost is recovered there.
500rwhp is the max we run 87-88mm at.The block flexes and cracks exturnaly on large bore motors and loose power due to bore flex.
We have seen 87mm bore RB26s with cracks .we use std or .5mm over bore in very high powered RBs.We use new blocks when the budget allows at a cost of around 2k but remember that much of the machining is already done so some cost is recovered there.  500rwhp is the max we run 87-88mm at.The block flexes and cracks exturnaly on large bore motors and loose power due to bore flex.
It is interesting how even very skilled people can have differing opinions and experiences. I have seen 86 mm (standard) bores with cracks as well, I don't believe that the bore size is the only reason. Temperature management, machining tolerances, metallurgy, boost pressure and parts used have as much to do with it as arbitrarily limiting bore sizes. Plus we never use "new" blocks, I much prefer an aged one. The more heat cycles they have seen, the higher chance there is that any manufacturing (and casting) stresses are long gone.
I like it when people have differing opinions, makes for an interesting discussion. :D
  • 10 months later...
can a rb30 block be fully boared out (to like 94mm) and have a full new sleve put in to run 89-90mm pistons? it would seal the water jacket at the top and bottom of block,
what do the os gikin boys do when resleeving there n1 blocks with the rb30 kit? does it rmove the whole existing sleeve or just enought to press in?
when a rb engine is re-sleeved is it fully bores out or not?
i did the maths checking out spaing etc, i could use 92mm pistons if this works, and have new sleeves and sill have 2mm of bore around hole cyl (is 2mm enought) idd say 90mm a reliaty tho, 87x90=3320cc nice
Adventurous, and I have no idea. RB30 blocks are cheap, all I can suggest is to try boring one cylinder and see how far you can go. It may also be worthwhile to check the cylinder head first. I don't think the water jacket will allow the combustion chamber to be much bigger than 88 mm. There would be no head gasket sealing surface.
From memory the OS Giken 3 Litre liners are around 5 mm thick at 86 mm bore, so that's ~96 mm OD.
:P
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
