ALL PARTS Located in the south east of melbourne 3150
Happy to post at buyers expense
I can text you photos if the parts for sale via SMS
0401035221
RB26 GTR push type gear box
Was working fine when removed
$400
AME TRACER
18x11 +10
Wheels are made by enkei
Same wheels used by cyber evo at WTAC
Small mark on the wheels nothing major
$2000
RB26 aftermarket camshafts
The camshafts came with a engine I bought is Japan, custom grind from a workshop in Japan
Have larger lift and duration but don't need to modify the cylinder head for clearance of the lobes
$300
R34 GTR z-tune fibreglass bonnet
$100
R34 z-tune front fibreglass gaurds
Only test fitted still new
$300
R34 GTR/GTT wide body rear fibre glass gaurds
Only test fitted
$300
RB26 M's pod filter
Suits cars with twin AFM
Fits all GTR'S
$60
R33/R34 standard shocks and springs
Used to pass roadworthys and defects
Actuall drives really smooth
$100
RB26 TPS
Brand new from nissan never used
OSGIKEN pull to push converter
Used but works perfectly
Suits RB gearboxes
$100
R32/R33 GTR Power FC
no hand controller
Works perfectly
$700
Racepace adjustable camgear a
Used but work perfectly
$50
V8 supercar spoiler
Fitted to a R34 GTR Boot lid with crush tube inserts
Paited black with 'Nissan' logo on the spoiler, genuine V8 super car spoiler came of a VX HRT CAR, carbon fibre blade etc painted black
$600
RB26 Conrods
Complete set, came out of a r34 GTR engine
$50
All parts located in the southeast of melboure
3150
I can send you a message with photos of the parts for sale
0401035221
https://www.sau.com.au/forums/topic/438112-gtr-parts/
R34 mines ducktail rear spoiler
Super rare, came off a RH9 drag car in Japan
$600
R34 GTR/GTT coupe carbon rear boot lid
Has 3 small holes drilled in it for the super car wing
Easy to repair
$200
0401035221
https://www.sau.com.au/forums/topic/438112-gtr-parts/#findComment-7182827
Hey mate in regards to the cams, does there need to be any replaced valve springs etc.. I know you said no head modifying required but just wanted to check because obviously it would be buying them with a bit of guess work ;)
https://www.sau.com.au/forums/topic/438112-gtr-parts/#findComment-7199342
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
