So my Origin boot lip and roof wing arrived from Japan via Streeter this week, yay!
What's the recommended way to prep these things? It's glossy black FRP, I saw somewhere that a light sand, primer and paint (maybe two coats) is all you need, is that right?
What about mounting them? Double sided tape, polyurethane, sikaflex, something else - what do you use? I'd prefer something that can come off a couple of years later without ruining the paint/glass..
The roof wing is a solid fit against the rear glass, the boot lip is ok but may need a bit of sanding in the middle to sit tight.
With the colour, I'm thinking of going gloss black for both, to kind of complement my matte black front lip (and the awse weather shields :) :
This is pretty close to what I'm after (from JDMST):
The alternative is body colour, it's classier but I kind of like the drift look above:
What says you?
You should be fine to use sikaflex or some similar adhesive. Grab a caramel wheel to get it off when/if you want to get the sikaflex off.
I used a wheel on (at least) 5 year old sikaflex that was hardened and it worked a treat.
Bought mine for $15 off ebay.
Thanks mate.
Any suggestions on how to prep and paint the FRP material properly?
Managed to get this done over the weekend, the prep was a bit tedious and I managed to get Sikaflex all over the place when mounting but it turned out alright. I might do a proper write up later on. Here's some quick shots prior to any wash/wax/polish, I'm hoping to get a bit more gloss once that's done:
EDIT: Does anyone know where to get a decent high mount brake light for the rear window? I don't think a parcel shelf one will work as it's obscured by the rear wiper...?
Edited by V28VX37
  • Like 2
I plastidipped my weather shields, one of those wings would tie in nicely in black
Good idea, did you have to pull them out for that?
I'm thinking black bonnet now too, although that could be a step too far...
Nah just masked it up with newspaper and tape post-493-13922029314971_thumb.jpgpost-493-13922029469582_thumb.jpg
  • Like 1
Not bad!
Turns out I didn't do the best job with sikaflexing the boot lip and it started coming apart at one end :/ Anyhow I pulled it off and spent an afternoon cleaning up the polyurethane ... and ended up painting the lip body colour whilst it was off the car :) It's yet to go back on, will post a photo once it's done.
Some photos below of how the boot lip looks after I changed my mind about the colour.
Couple of tips for anyone wanting to mount theirs properly:
  • Make sure the fit is good before priming and painting. I ended up sanding back the inside middle section for a better fit before repainting the whole thing...
  • Do not go anywhere near the edges with Sikaflex. On the first go I went maybe 10-15mm from the edges and a fair bit squirted out, it's a prick to clean. Second time 20mm or so away and it was pretty good all around. Also, do not try this on a 40 degree day like I did the first time around, it will not cure properly.
  • Second time I used 2 ratchet straps to pull the lip forwards and down at each end, plus a plank sideways across the whole lip, held down but clamps at each end. Let it sit for 48 hours. Much better.
  • Oh and I didn't find any way to get a proper glossy finish at home (black or coloured, with or without clear coat), I reckon you need to bake the paint for that. Oh well.
  • Like 2
  • 1 month later...
Thanks guys! Yeah definitely test for fitment before mounting, much quicker than fitting it twice...
Mine's stayed on perfectly for two months now. Here's a behind the scenes shot, I let it sit like this for 48 hours to cure properly:
  • Like 3
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
