Very nice. Do you have much problem with rust over there, with all the snow?
Thanks :) Snow isnt the problem, but salt used to keep ice out of the road is.. But here in northern Finland they doesnt use it so much :)
^^^ Looks awesome!
I just can't get over seeing an R34 against the quintessential Finnish backdrop ... it's a loooong way from Yokohama :)
Thanks :) Yeah, its isnt the usual backdrop :D
Yeh that's what I was getting at; I had a look under my Opa's car in Germany once. 1997 Audi S4, had so much rust underneath it made me nervous getting in it. Still, beats sliding off the road because they didn't salt it!
Haha :D Luckily i dont drive my r34 at winter. I dont care if my bmw get some rust :D
Looks good.
Front bar is a bit too solid for me.
The division between lip and bar actually helps.
Also with the side all closed up :P
Thanks!
You mean holes in stock gtr lip? I think theres no big benefit of those if you dont have air ducts installed :)
Edited by Guula
Hi Markus,
Love your work. I like the body kit work you have done.
Also appreciated the fact you seem to be majority of the work yourself.
The R34 looks nice smooth. Bet you she loves the cold too ;)
I miss Finland very much and have even been contemplating relocating there, and if do I would take my R32 GTR with me.
Will keep an eye out on this thread.
Top stuff
Hi Markus,
Top stuff
Thanks mate! :)
recon you should shave the door handles !
My friend said the same :D But im not going to go there now, maybe later if repaint the car etc..
I just drove little 1300km road trip and next thing is raise the boost 0.7 -> 1.2-1.3 and tune it :) Turbo and new screamer are awesome!
  • 4 weeks later...
Like to see a DIY on making that front lip?
I have to check how much i have photos of making it :)
How did you go, any dyno results yet?
Hope to get it tuned next week.
My clutch release bearing started to make some noise so had to repair it week ago.
Also replaced all bushes from rear. Much more solid rear now :)
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
