Do you have an oil pressure sensor and a stock GTR boost pressure sensor, i need both with a little bit of the harness.
Pm me if have those (tried to PM you but wouldn't go through)
-Kyle
  • 3 weeks later...
Hi all hahahah as stated contact on mobile and I'll get the parts sorted for you.
4wd pumps coming out tomorrow coil overs are tein and ohlin mix pair 500$
Not much has sold as not many messages on mobile, gearbox gone.
Location is Newcastle pick up only really or expect to pay packing time and time organising postage.
Door in good nick 100$ each
26 engine loom 150$ good nick
Carpet in mint condition
If you need parts just orgainse to come and get them hahahha
  • 8 months later...
Front Right lower suspension arm. Mine bent on a gutter :) Not sure what else is bent yet but that defeintely is
Front right guard
Drivers Door pillar down to the rivets half way down the door and up to the roof.
Complete roof section
Got anything?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
