It seems someone has been back, a few M35 Stagea parts have been stolen since. I really hope it isn't someone I know with a Stagea but it's useless to anyone else... Try and help people and this is what I get. :/
Cameras will be installed today fagt, come back and I will be ready for you.
Pretty gutsy going back for more.
Don't tell em the cameras are getting installed, you want them to come back with them on!
Though it's likely they haven't even seen this thread if they returned.
Well that's fuarked...
My suggestion would be (having been raised in Sydney's Western suburbs), mount cameras where people won't think to look. So not on the wall in the corner, but more at a lower height on a wall with the lens facing up. Depends on the range and vision of the camera though. Many many years ago, a mate had shit go missing and it looked like someone had a key to get in. He set up flood lights but left them on the floor and had the sensor near his shit. Looked like they were lying there waiting to be mounted but he'd left it like that intentionally. Thief comes back, finds out it's his ex selling shit for next to nothing to get back at him... But a few ideas any way. Shit blokes know where to look for cameras and lights. Although, in this day and age, you can get really tiny powerful shit that can be hidden anywhere. Hope that helps!
I want them in view as a deterrent, the parts I leave out usually don't have much value anyway. As long as the customers cars are recorded i'm happy, as I have done my best to stop opportunistic thieves. The ones that want something in particular won't be stopped by cameras or padlocks.
These are 4 of the wheels that were taken. JDM VENERDI 19" Chrome. Likely to be TOTALLY unique in VIC.
Been trying to sell them for the past couple of months...
Anyone seeing them, PLEASE let myself or Scotty know. they are 5x114.3 so will fit ford or Jap wheels.
Yes Lifted, been on eBay for a while.
what's worse is that they are REALLY nice wheels for the right car. and you can't get that stuff here. I was even getting tempted to put them back on my stag.. Anyways.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
