my reason for asking this is because my R34 pulls to the left no matter how i set up my caster and im interested to see what caster as well as camber everyone else is running
Whats your front Toe in/out (Left and Right) ?
Post your set-up and it may then become obvious to others to point you in the right direction
Edited by Sinista32
Put More caster on the left than the right
Maybe Left 5 and right 4
Toe +1.5 on front both sides
Edit: Have you had any front end damage ?
Edited by Sinista32
tried that and it made it pull even more left and made my steering wheel more off centre
extending the length of the tension rod i.e. making it longer would increase the caster positively right?
i even made the left maxed out as long as it would safely go and made the right side as short as it would go and it was still worse then what is posted in that pic thats why im so confused ive been trying different caster adjustments for days
what can accentuate when driving is that the roads are built with camber dropping off to thee side of the road. So most cars will drift to the edge
Unless the alignment is set to combat this. When you test drive use different roads. As some roads are just worse than others.
Im no expert. so for $85 the wheel alignment place should sort it .
could it be that it's bent up front ?
Edited by Sinista32
i have SRI tension rods not sure they can get to 5', and if so it would make my wheels rub on the inner plastics
on that pic my left was 4 threads out = 2'46 and the right was on 7 threads = 3'34, they can only get to like 8/9 threads before i think its not safe so that gives you an idea of my room to play with
and yep just found this out recently too, but compared to driving numerous other cars that i can let go of the wheel for whole straights pretty much and i cant let go of mine long enough to plug my phone into the aux
I run 6 deg left and 5.75 right Castor. I have Cusco arms. You have a lot of negative camber c/w a small castor angle which would make the car very twitchy anyway. Your rear camber is getting up there too - is it set for slicks or because you can't fit your wheels in your guards? Also try setting the toe in to zero. If your rear toe in is still as far out as your details suggest (it doesn't show any corrected figures) then that won't help keeping you going straight either. If it is still pulling hard left you or someone is likely to have whacked a kerb or something and if you can't see any obvious damage you may consider getting it put on a chassis alignment rig at a panelbeaters.
my wheel shop wont touch my adjustable arms because of the effort to take them half out to adjust them, so they have only been able to give me advice on where my castor should be. and for $65 a hit it will get pretty expensive to take it in after every adjustment.
i originally snapped the stock castor arm then bought a replacement and it pulled to the left so i got the adjustable ones and still pretty much the same amount of little pull to the left.
nothing looks bent but there could be something sneaky but wouldn't it show in the wheel alignment sheet
If the wheel alignment is dialled in correctly then only driving it will tell you there is something wrong which it has. Pointing to damage
So your alignment needs to compensate for this or you'll need to resolve any damage
I don't know how your castor arms work but I don't have to remove mine to adjust them.
If you read my post sentence by sentence you will see that in my opinion (you are entitled to yours) there is a lot wrong with your alignment. Once it is right then if your car still pulls left you have damage somewhere.
i have to take out the two bolts that connect it to the knuckle and twist it from there (pretty sure thats how im meant to do it anyway haha)
i agree there is a lot wrong with my alignment thats, thats why i want to see how it should be set up and then hopefully it doesnt pull left and i dont have any chassis damage ect,
tomorrow ill extend my tension rods to get a higher castor and aim for around 5.5 on the left and 6 on the right
i dont know hoe to adjust the toe so ill have to wait till i go to the shop for that, where should it be set? and ill adjust the camber to around -1/0?
Edited by IMPORTS ONLY
Um....no. You release both the plated nuts (at either end of the red section) and then you can turn the red section to lengthen and shorten, then nip up the nuts again. It is really very obvious when you look at it properly.
And even if you did have to undo the two nuts attaching it to the lower arm....that's about 15 seconds each with a rattle gun. I do mine lying on my back on hot concrete with a breaker bar and ratchet not much slower than that!
i thought i was doing something wrong haha, ill fix them up today so they adjust properly
Also to get more caster, you shorten the tension rod, not extending it
this confuses me because my right castor arm is extended longer then my left and has a higher positive castor? so moving the the front wheel forwards towards the front bar by shortening the rod would be adding to positive castor and moving it backwards towards the rear of the car by extending the rod would make the caster less positive?
Correct
wheels forward = more caster
With rwd skylines 7 degree is good
Stock setting is around 5 I think?
I think ur caster is way off @ 3 degrees & 2
Shorten the left side some more first and work from there
Edited by chiksluvit
I know I have a wagon and you don't but it is AWD and the weights and suspension are not that different so I'll give you my figures as a concrete goal. You may want to change them to suit your car and use ...
Castor L 6deg R 5.75
Camber 1.5 neg L & R
Toe 1mm toe out L & R
Rear camber 2 deg neg
Toe zero L&R
When you adjust front camber your toe will go miles out. You can adjust it roughly by eye and you can roughly measure your camber with a spirit level if your maths is not too bad. I don't know how you can measure castor except on the machine. Maybe you could look around for a better alignment operator as well!
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
