my missus ran it on 91 with E10 while i was overseas for a week and when i got back and drove it i could feel the engine jittery. feels like incomplete burn / running lean and the car was very underpowered, even the gear shifts seemed lazy.
so yes it can run it but it will kill your engine in the long run as the mapping and engine fuel management is intended for ron 95 or 98
i tend to fill up usually when it gets half way and il alternate sometimes 95 sometimes 98 and it runs smooth, no noises, quick response and unexpected surprises.
I ran 95 for a while when I first bought mine, I have since switched to 98 because it is only about 2cpl more than 95. I haven't noticed any difference in economy or performance.
From memory, Japan has 96RON.
E10 can be anywhere from about 91 to 96 RON depending on how long it has been sitting around.
United sell premium 100.
That's what I would be using if I wasn't tuned on their e85.
United 100 octane is garbage. its not really 100octane since it uses 10% e10 to boost the octane rating. been using it until i got my car uprev tuned and now running shell 98, much better
how do you know you get better economy if you have run 98RON 'since day one'?
Would you drink diet coke or normal coke? Normal because you know that its nicer and better than its "alternative" Edited by Howaitonaito
I always used RON98 on my 350GT in the past. Had to pump RON95 into it a couple of times when I was out of town and couldn't find a station with RON98 and noticed that the engine tends to be abit more sluggish. Anyway, the manual states that premium fuel should be used and I think I recall reading somewhere that premium fuel is basically at least RON97 or more so I always put RON98 in and have done the same for my 370GT.
Not really a relevant comparison, higher octane fuel only has a higher resistance to detonation, if you aren't detonating on 95, then 98 will do nothing for you.
I found no difference between 95 or 98 in regard to economy or performance, and I only run 98 now as I believe Japan's fuel is 96 and I prefer to er on the safe side.
Ive had two nissans before this both australian delivered cars and both went further on 98 than they did on e10.
I got told to put 98 in it when i bought it and i have. Always BP ultimate or Shell V-power (v power in a v)
Of course. Ethanol has a lower energy density
I have had 3 Nissans before the V35 and none of them benefited from running a higher octane fuel than they were made for.
if the V35 is indeed made for 96RON, then my preference is not to go below that, which means 98 is the best option.
Edited by sonicii
Question for those who have the ability to map / record engine parameters.
Have you seen the ECU ever actually take out timing due to the knock sensor sensing knock?
The knock map is just a secondary Table for ignition values, I don't believe it alternates between the two, but just throws a CEL and then switches over.
I've seen a motor die (nil compression) due to a bad tune knocking (electrodes off the sparkplugs). Yet the knock sensor seemed to do SFA. Unless the tuner didn't complete the knock map, or the knock map wasn't touched and had higher than tuned map values, in which we'll never know.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
